Thread: Odd A/C Issue
Results 1 to 6 of 6
  1. #1 Odd A/C Issue
    Feb 2013
    Ohio
    I have a 2005 GTP Comp G. When I bought it, the a/c compressor was leaking. I changed the compressor, vacuumed the system and charged it up. Leaked out again after a few days. Found that the core on my low side line was leaking. Changed the core, vacuumed it down again and charged it up. A/C now blowes ice cold and it's not leaking anywhere. The issue I'm having is when I start the car and turn the a/c on, the compressor engages and the fans kick on high, but it doesn't blow cold. I have to shut the a/c off and wait for the compressor to disengage, and then turn it back on. Then sometimes it starts blowing cold. It's hit or miss though. Sometimes it takes a dozen times of turning it off and on, sometimes I only have to do it once. Once it starts blowing cold, it stays blowing cold. Even if I shut he car off for a short period of time and start the car back up, it still blows cold. Every time I turn it on though, the compressor engages and the fans kick on high regardless of if its blowing cold air. It's getting aggravating. It's suck a goofy problem that I'm not even sure how to google the issue. Any ideas? Thanks!
  2. #2 Re: Odd A/C Issue
    GXP Level Member
    Mar 2015
    Tomball
    Could it be that the blend door is stuck, sticking?
  3. #3 Re: Odd A/C Issue
    Feb 2013
    Ohio
    I don't think it's the blend door. I can change it from "60" to "90" (digital climate control) and it'll blow hot air. When the compressor is running but not blowing cold air, I can just push the a/c button and it'll kick the compressor off with the blower motor still running. Then push the a/c button again to turn on (or sometimes 15 times) and then it'll blow cold. All without adjusting the temperature.
  4. #4 Re: Odd A/C Issue
    GXP Level Member
    Mar 2015
    Tomball
    Does the light come on to indicate the AC is on? I've had issues with it and have to wiggle it press to one side to get the damn thing to turn on. But the light is out until it finally makes contact.
  5. #5 Re: Odd A/C Issue
    Feb 2013
    Ohio
    Yep. Light turns on and off as it should and the compressor kicks on and off with the button every time.
  6. #6 Re: Odd A/C Issue
    GXP Level Member
    Mar 2015
    Tomball
    Weird
  1. Weird speedometer issue, possible trans issue?
    By Peder in forum General Tech Discussion
    Last Post: 07-28-2014, 07:08 PM
  2. Issue with A/C no more cold air and sound issue with Shocks
    By ibra0078 in forum General Grand Prix Discussion
    Last Post: 08-09-2013, 08:25 AM
  3. Wheel Bearing Issue or Tire Issue
    By ibra0078 in forum Tires & Wheels
    Last Post: 06-07-2013, 05:12 AM
  4. 97 GTP issue w inside Fan/Blower issue
    By JoeRappa in forum General Tech Discussion
    Last Post: 10-03-2011, 10:16 PM
  5. car issue?
    By GTP Ryan in forum Off Topic Discussion
    Last Post: 08-27-2011, 11:06 PM
