Thread: Cruise control and lock up problem
Results 1 to 7 of 7
  1. #1 Cruise control and lock up problem
    Jul 2016
    Kansas City
    Not sure if this is the right place to post this as I am new but I just bought an 06 grand prix gxp, upgrade from 00 GP gtp, and I'm having a slight problem. Apparently there is a p0573 code that the transmisson place that I took it to found but the problem I'm having is that the cruise control will not work and tcc will not lock up. Cruise will flash on for a split second then back off. I have replaced the brake light switch but did not fix the issue. Brake lights light up fine, not sure if the issue could be that they are new LEDs and a new spoiler with 3rd brake light, I added resistors to the 2 LED brake lights but still nothing. I took to the trans shop because it was reaching 235 degrees during 30min+ highway driving, they thought the brake light switch would solve both problems because if the tcc will lock up it will cool the trans more and the cruise will work again. Thanks
  2. #2 Re: Cruise control and lock up problem
    GT Level Member primem's Avatar
    Sep 2013
    Calgary, Alberta
    is the p0573 still setting? If yes, unplug the connector to the switch and check for grd on the black wire, 10 volts on the gray wire reference and for some reason the diagram show 10v supplied to the lt green signal wire.
    2004 comp g
  3. #3 Re: Cruise control and lock up problem
    Jul 2016
    Kansas City
    Quote Originally Posted by primem View Post
    Just figured it out! When the guy before me put the new spoiler on he didn't add a resistor so I threw one on there just to see and bam it works.
  4. #4 Re: Cruise control and lock up problem
    GT Level Member Hurricane87's Avatar
    Jul 2016
    Brevard County, FL
    Quote Originally Posted by tigerwkb View Post
    Mods. The second dumbest thing ever invented for cars.
  5. #5 Re: Cruise control and lock up problem
    Nov 2012
    Toronto, Ontario, Canada
    What size resistor?
  6. #6 Re: Cruise control and lock up problem
    Jul 2016
    Kansas City
    Quote Originally Posted by chrias View Post
    What size resistor?
    I can't remember but it was the only load resistor oreilley's had
  7. #7 Re: Cruise control and lock up problem
    Nov 2012
    Ok, so it's a load resistor. Thought you used a regular resistor. Lol
  1. Minor cruise control problem only when it's cold
    By binnes in forum General Tech Discussion
    Last Post: 12-03-2014, 11:30 AM
  2. Strange Speedometer / Cruise Control Problem
    By jimhollis in forum General Tech Discussion
    Last Post: 03-27-2014, 10:19 AM
  3. cruise control problem- how to diagnose?
    By genki in forum General Tech Discussion
    Last Post: 08-30-2013, 08:07 AM
  4. Cruise control problem
    By Dozerman51 in forum General Tech Discussion
    Last Post: 08-29-2013, 09:30 PM
  5. Cruise Control problem.
    By jordyfallacy in forum General Tech Discussion
    Last Post: 03-08-2010, 11:32 PM
