Thread: 2000 Gp GTP starts but dies 2 secons later
Results 1 to 13 of 13
  1. #1 2000 Gp GTP starts but dies 2 secons later
    GT Level Member 99GPGTP's Avatar
    Rome GA
    my co worker has a 2000 grand prix gtp 2door that will spin over and fire up but dies 2 seconds later, no codes stored. sometimes when i hook up scanner i get no comunication, all fuses are good in car. the DIC doesnt work at times but im pretty sure thats not the cause. i think its a symptom. sometimes the car will fire up and run just fine. couple months ago it had a security code but not any more. the security light goes after a couple seconds of putting in the key and turning ignition on.
    if anyone has any info that might help is please let me know. i work as a mechanic but this has us all stumped. we do know the fuel pump still runs and has fuel pressure. the injector noid goes away and car dies.
    99gtp 3.4"on ported m90, zzp 1.0 pcm, speeddaddy headers, stock mufflers w/cat and res delete,104's,FWI,180* stat, exhaust ported heads,Dog bones flipped, 18" 350z wheels
  2. #2 Re: 2000 Gp GTP starts but dies 2 secons later
    Rome GA
    also. it still fires when it dies, new cam and crank sensor
  3. #3 Re: 2000 Gp GTP starts but dies 2 secons later
    try this.
  4. #4 Re: 2000 Gp GTP starts but dies 2 secons later
    Rome GA
    car has great fuel pressure. do u think that will fix this?
  5. #5 Re: 2000 Gp GTP starts but dies 2 secons later
    Quote Originally Posted by 99GPGTP View Post
    its worth a shot. start and stall is related to that pic and the resistor, bending that tab puts the pump in hi speed mode full time.
  6. #6 Re: 2000 Gp GTP starts but dies 2 secons later
    GT Level Member willie14's Avatar
    Jun 2016
    westland mi
    Is this bypass a way to just get more out of stock fuel pump & injectors? Curious it seems to be a similar resolve like the voltage rewire kit...
    98 Grand prix SE to GTP conversion( in works). Full body conversion in works, drilled n slotted rotors, ceramics, all new suspension, custom CAI, NGK wires/Vpower plugs, SD headers, 180 Tstat, AND A WHOLE BUNCH OF PAINT BABY!! Tuned by E&J performance.
  7. #7 Re: 2000 Gp GTP starts but dies 2 secons later
    no. its to bypass the high speed resistor when it fails. read the words on the pic.
  8. #8 Re: 2000 Gp GTP starts but dies 2 secons later
    Rome GA
    tried bending the tab, it didnt help. car still dies after 2-3 seconds
    forgot to mention. fuel gauge stopped working and this problem started. Installed new fuel pump last month. problem still there. used a delphi stocl replacement pump. new fuel pump relay also
  9. #9 Re: 2000 Gp GTP starts but dies 2 secons later
    the security light on? maybe try another key?
  10. #10 Re: 2000 Gp GTP starts but dies 2 secons later
    Security relearn is the next step to me or try another key.
  11. #11 Re: 2000 Gp GTP starts but dies 2 secons later
    Rome GA
    tried another key, security light goes off. i think its the pass lock
    could the icm cause this.
  12. #12 Re: 2000 Gp GTP starts but dies 2 secons later
    Rome GA
    just found the problem, had a loose ground on the battery cable to the body
  13. #13 Re: 2000 Gp GTP starts but dies 2 secons later
    nice find.
  1. 2000 Grand Prix GT starts easily then dies after 2-3 seconds
    By coolhand in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-02-2015, 05:49 AM
  2. 98 GTP starts and dies intermittently on cold starts
    By toadson in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-16-2013, 07:53 PM
  3. 2000 gtp reading 98 on barametric and starts and dies
    By Mjt2000gtp in forum Introductions/Noob Questions
    Last Post: 11-14-2012, 05:01 PM
  4. 99 gtp starts then dies..
    By 2004pontiac in forum General Tech Discussion
    Last Post: 12-24-2011, 01:12 AM
  5. HELP: Starts then dies after LIM
    By rfmgtp02 in forum General Tech Discussion
    Last Post: 06-23-2009, 03:35 PM
