Thread: Hard shift to reverse from park when cold
Results 1 to 3 of 3
310toumad Hard shift to reverse from... 08-06-2016, 08:09 PM
Scottydoggs Re: Hard shift to reverse... 08-06-2016, 08:12 PM
310toumad Re: Hard shift to reverse... 08-06-2016, 08:39 PM
  1. #1 Hard shift to reverse from park when cold
    Sep 2015
    IL
    I only experience this problem on cold starts: I have to apply a considerable amount of pull to move the gear selector from park to reverse, feels like a lot of resistance. It also is usually accompanied by the engine/trans lurching quite a bit with a clunk/pop sound. I recently changed the mounts and double checked the nuts were tight, so I don't think that's an issue. Checked the trans fluid and its fine. Once the car has warmed up it shifts to reverse much more smoothly, and usually no clunk. Other than this issue the trans shifts perfectly fine in all gears, no check engine light is on, etc. Any ideas?
  2. #2 Re: Hard shift to reverse from park when cold
    you park on a hill or any thing of incline?
    stet the parking brake, then put the car in N for a second to let the brake hold the car, then into park. this way theres no weight pulling on the tranny.
  3. #3 Re: Hard shift to reverse from park when cold
    Sep 2015
    IL
    Don't park on any sort of incline at home or at work.
  1. Park and Reverse are gone? (SOLVED)
    By mitchd123 in forum General Grand Prix Discussion
    Last Post: 05-28-2015, 07:45 PM
  2. Reverse feels like park
    By TimMcCallum in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-07-2014, 07:54 PM
  3. Park to reverse thunk, which mounts? (video)
    By jasonnovak in forum General Tech Discussion
    Last Post: 12-27-2013, 10:11 AM
  4. Shift from park to reverse or drive, quick question
    By calvin in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-21-2011, 04:20 PM
  5. Park to reverse
    By shawnschuldt in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 12-28-2010, 12:14 AM
