Thread: 99 GPGT Passenger inside door lock and key lock not working at all.
Results 1 to 7 of 7
  1. #1 99 GPGT Passenger inside door lock and key lock not working at all.
    Aug 2011
    Bucks County Pa
    Passenger door look was working off and on for a while with the key fob now nothing is working. I tried the key to open the door and nothing works. Seems like it's jamb now, can't open the door. What could it be? What needs to be replaced? Just to make it clear all the other three door work perfectly just the passenger door is the problem.
  2. #2 Re: 99 GPGT Passenger inside door lock and key lock not working at all.
    St. Louis
    Do you hear the lock actuator moving when you hit the button on the key fob?
  3. #3 Re: 99 GPGT Passenger inside door lock and key lock not working at all.
    Aug 2011
    Bucks County Pa
    Yes but just a slight noise. Its seems jamb somewhere.
  4. #4 Re: 99 GPGT Passenger inside door lock and key lock not working at all.
    will it unlock manually? most of the time the plastic ends ont eh rods break then the rod has play in or it falls out of place.
    or the lock actuator went bad.
  5. #5 Re: 99 GPGT Passenger inside door lock and key lock not working at all.
    Aug 2011
    Bucks County Pa
    Can't unlock with the key on the door.
  6. #6 Re: 99 GPGT Passenger inside door lock and key lock not working at all.
    not to be an asshole, but theres a lever on the inside of the door, aka manually with your finger unlock it.
    cause if you can open the door at all your kinda fvcked here. the inside door cover needs to come off.
  7. #7 Re: 99 GPGT Passenger inside door lock and key lock not working at all.
    Aug 2011
    Bucks County Pa
    Actually I did get the door open by getting the door panel off, so your comment is being an ass hole! LOL!
    I guess I can get a complete used lock actuator and see if that works!
  1. Replacing passenger door lock actuator
    By LS1GTP in forum Visual/Body Modifications
    Last Post: 02-11-2013, 05:17 PM
  2. Door Lock Actuator Replace - Now doors won't electronically lock
    By rmortime in forum General Tech Discussion
    Last Post: 11-17-2012, 12:37 AM
  3. 1997 GTP Passenger Side Door Wont Respond to Lock/Unlock
    By Calikid219 in forum General Grand Prix Discussion
    Last Post: 05-21-2012, 09:57 PM
  4. One Door lock not working
    By drmurdoc in forum General Tech Discussion
    Last Post: 07-11-2011, 04:33 PM
  5. remote door lock horn only when lock ?
    By NEONNIGHT34609 in forum General Tech Discussion
    Last Post: 12-10-2008, 09:05 PM
