Thread: RPM's raise and drop then car dies. Any ideas?
Results 1 to 3 of 3
Threaded View
  1. #1 RPM's raise and drop then car dies. Any ideas?
    Jul 2016
    Midwest
    Hello, all,
    I've googled far and wide and can't find a solution. No codes are showing.
    History: 04 Grand Prix (206k). While driving down the highway, RPMs will drop off and/or jump up suddenly. When this begins, the throttle will be hit and miss and 20-30 seconds later the car dies and I have to pull over and start again. This has happened 3 times and each time it started back up on the third try.
    Prior to the problem and within the last month, I replaced the air filter, thermostat and MAP sensor for emissions testing. After the first time it died, I cleaned the TB and the MAF sensor as I'm familiar with that process since I had the problem of starting the car a few years back. However, it's happened again twice since cleaning.
    After reading everything I've found online I've seen suggestions such as Crank Position Sensor, Throttle Position Sensor, Wire Harness, Ground Wire Corrosion, Loose Belt Tensioner, IAC, etc.
    Can anyone help? The most recent post I've seen is 2011 so hopefully someone has a solution by now. ....Hopefully?
    Thanks.
  1. New Battery, New Alternator, Battery still dies. Any Ideas?
    By bjornbjorn in forum General Tech Discussion
    Last Post: 03-19-2015, 10:05 PM
  2. Replies: 11
    Last Post: 04-19-2014, 11:00 PM
  3. "wrong" struts wanted for front of 97GTP to raise it..
    By darkhorizon in forum Brakes/Suspension/Chassis
    Last Post: 11-03-2013, 07:47 PM
  4. starts for 1 sec. and dies, need some ideas
    By pureroundcircle in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-29-2011, 01:44 PM
  5. What is the biggest raise you have gotten?
    By shaferz in forum Off Topic Discussion
    Last Post: 01-11-2008, 05:36 AM
