Thread: Blew fuse that cut off abs/traction/stability/power steering on 2008 gxp
Results 1 to 4 of 4
  1. #1 Blew fuse that cut off abs/traction/stability/power steering on 2008 gxp
    Aug 2014
    grandville
    I replaced the blown 10a fuse and it worked fine for a whole 30 seconds then I blew another 10a fuse. Anyone had these issues or was it just a **** fuse
  2. #2 Re: Blew fuse that cut off abs/traction/stability/power steering on 2008 gxp
    If you keep blowing fuses that usually means that you have a wire grounding out that should not.
  3. #3 Re: Blew fuse that cut off abs/traction/stability/power steering on 2008 gxp
    Aug 2014
    grandville
    Hmmmmm it just randomly happened. I'll try another fuse or 2 to make sure then I'll have a buddy look at it. I'm not that car savvy to figure it out
  4. #4 Re: Blew fuse that cut off abs/traction/stability/power steering on 2008 gxp
    I would rather burn a car to the ground than try to chase down an electrical issue.
  1. 2006 gxp power steering line blew
    By Ben10125 in forum General Tech Discussion
    Last Post: 03-04-2015, 06:19 AM
  2. 2008 Grand Prix: Where in the heck is the Power window fuse!!
    By mcdavidhome in forum General Grand Prix Discussion
    Last Post: 08-26-2013, 04:07 PM
  3. Replies: 25
    Last Post: 01-26-2013, 11:52 PM
  4. service power steering abs system traction control warning
    By ltr450tremor in forum General Tech Discussion
    Last Post: 05-06-2011, 10:14 PM
  5. abs/traction/stability service lights
    By jackster1234 in forum General Tech Discussion
    Last Post: 11-09-2010, 01:01 AM
