Thread: New battery cables for 3800
Results 1 to 2 of 2
  1. #1 New battery cables for 3800
    Oct 2011
    Texas
    Does anybody have a diagram or can describe the routing of the main battery cables on a 3800? I am looking at replacing the positive and negative on my 98' is hopes that it may be the reason for my slow drain and issues starting occasionally (I have already looked at other potential issues). Also if someone could add info on grounding points that would be helpful as well (I know there is one on the body and transmission housing?) Thanks in advance.
    Current = Turbo, E85, XP, and Tengis Tune
    Old = L36, ported Gen3, IC, XP, Stock Heads, E85, Headers, and Tengis Tune
  2. #2 Re: New battery cables for 3800
    bad cables should not make the battery drain, but can cause a weak starting condition.
    if your set on replacing them, remove them, then take em to the parts store and match em up for length. the start at the bat, then run along the front sub frame to the starter and the bell housing. they must be like 5 foot cables.
  1. Dead battery, no amp draw and battery tests fine
    By pontiac98 in forum Audio, Security & Visual Electronics
    Last Post: 01-04-2016, 09:44 PM
  2. Battery Cables HELP PLEASE:(
    By Massey936 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-31-2013, 11:15 PM
  3. 2004 GT1 - Battery Cables
    By 99XC600 in forum General Tech Discussion
    Last Post: 04-29-2012, 01:40 PM
  4. Replacing main battery cables
    By Impala131 in forum Audio, Security & Visual Electronics
    Last Post: 04-26-2012, 05:04 AM
  5. Best place to get battery cables
    By GTP in RTP in forum General Tech Discussion
    Last Post: 12-19-2011, 05:59 PM
