Thread: PS leak. What line is this? Part #?
Results 1 to 7 of 7
  1. #1 PS leak. What line is this? Part #?
    SE Level Member Drive XR7's Avatar
    Cleveland, OH
    Have a pretty significant power steering leak that has gotten worse. It seems this metal line has rusted and rubbed against the brace which has caused the leak. What line is this? It seems to snake down and around the undercarriage and back up. You can see the leak actively occurring -- small puddle after only a few minutes. Anyone have a part number? Hard to replace?
    I intend to fix this and then put the car up for sale. It's pretty clean otherwise.
    Jason
    2001 Bronzemist Pontiac Grand Prix GTP - SOLD!
    2003 Sonic Blue SVT Mustang Cobra Convertible #2421 (1 of 340)
    2013 Ruby Red Ford Edge Limited EcoBoost
  2. #2 Re: PS leak. What line is this? Part #?
    trace it to the pump, the line with a line nut is the high pressure line, the one with a rubber end with a clamp is the return line.
    id cut that line and put a compression fitting on it in a heartbeat. but thats me lol
  3. #3 Re: PS leak. What line is this? Part #?
    Cleveland, OH
    Looks like this is the return line. First review describes my exact problem. Road grime gets stuck in the "3" pipe bracket and wore a hole in it.
    http://www.amazon.com/ACDelco-36-370.../dp/B005536M2W
  4. #4 Re: PS leak. What line is this? Part #?
    Cleveland, OH
    I need to put a bandaid on this tomorrow (Memorial Day) because I need to drive the car to the airport on Tuesday, returning Friday. By then the actual correct part will be at the house.
    I think by fumbling with it today I made the leak worse, lol. So tomorrow I'll try to cut the pipe and slide on some 3/8 fuel hose and secure with some clamps, which I have in my garage. If that doesn't work, I may be out of luck and taking my Cobra to the airport (ugh) instead.
    Jason
  5. #5 Re: PS leak. What line is this? Part #?
    if thats the hi pressure line it could fail. compression fittings are like 2 bucks.
  6. #6 Re: PS leak. What line is this? Part #?
    Cleveland, OH
    Looks like this is low pressure. And it's already failed, couldn't get much worse.
    Jason
  7. #7 Re: PS leak. What line is this? Part #?
    GT Level Member chrishova's Avatar
    Norfolk, Virginia, United States
    What size compression fitting would be good? How hard is it to run a whole new line? I saw this as a replacement https://www.rockauto.com/en/moreinfo...sn=714&jsn=714 . Is a cooler a good option?
  1. transmission cooler line part number?
    By andremike in forum General Tech Discussion
    Last Post: 11-17-2014, 08:31 PM
  2. I need this line.... Can you identify a part number for me....pic included
    By TwiztdWun in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-06-2013, 12:34 PM
  3. Vacuum Line Part Number?
    By jakobkay in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-21-2012, 01:23 AM
  4. L67 Vacuum Line Kit Part Numbers and Prices
    By MoarkatsINmuhtrailer in forum How To Write-Ups/Tech Tips
    Last Post: 01-16-2012, 01:19 PM
  5. brake line replacement part
    By mac507 in forum Brakes/Suspension/Chassis
    Last Post: 01-11-2011, 07:49 PM
