Thread: Aeroforce full install
Results 1 to 15 of 15
  1. #1 Aeroforce full install
    GT Level Member ShadowSwept's Avatar
    Kentucky
    So I know the easiest way to install the scangauge is with an add-a-circuit, but say I don't mind splicing wires, would there be a good wire to tap near the A-pillar?
    2001 Bonneville SLE - L36, Cone Filter, 200k miles
    2003 Grand Prix GT
    - L36, Short Ram Intake, HV3, Emissions Delete, ZZP 3" Downpipe, Overkill Tune, 200k miles
  2. #2 Re: Aeroforce full install
    dont take a chance, run the wire to the fuse box.
  3. #3 Re: Aeroforce full install
    Kemmerer, Wyoming
    use an add a circuit and tap it into the fuse block next to the glove box. when I did it, I used a wire that had multiple strands, so when I added more gauges I already had power run to that area.
  4. #4 Re: Aeroforce full install
    Awesome Level Member chrsmi1's Avatar
    Jan 2013
    Raleigh, NC
    Quote Originally Posted by SgtMarshal View Post
    This.
    Comp G. E85, 2.8, Headers, Tune, Intake, S1X, 105# springs, 60 # injectors, 255 walbro,etc.
    *NEW* 2002 Camaro Z28- Lid, Headers, Catback
  5. #5 Re: Aeroforce full install
    Jul 2010
    Coquitlam,BC,Canada
    Quote Originally Posted by ShadowSwept View Post
    Find "ignition hot" in the ignition harness. Easier to go to the fuse box though.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  6. #6 Re: Aeroforce full install
    Kentucky
    Quote Originally Posted by Bronco Boy View Post
    Red or pink?
    I know the add-a-circuit is the easiest way, but I'm looking for a 'factory-clean' install and would rather not have wires cluttering up the fusebox.
    Most say to use the window fuse with that install, couldn't I tap the same circuit near the driver's door, or maybe splice into the gauge harness? Just looking for alternatives to the add-a-circuit.
    2003 Grand Prix GT
  7. #7 Re: Aeroforce full install
    GTP Level Member Tonkin2000GT's Avatar
    Jul 2015
    Jamestown, NY
    Do you have a 97-03 grand prix if so there's a unused plug under the glove box you can buy zzp's drop down harness that plugs right into it worked great for me. It's running to its own fuse to safest easiet way to do it. There's 3 wires on the plug ground, constant hot, and accessory hot which is the one I hooked it to so it turns on and off with the car. You have to pull the little jumper fuse out of the back of the aeroforce to. I just did mine last summer if you need a picture of where the plug is let me know.
    Sent from my SM-G920V using Tapatalk
    00 Grand Prix GT, top swapped, .020 FMP, GT1 Cam, SFI Crank pulley, SSM90, 3.3 MPS, ZZP ported Gen 3/LIM, ported heads, #90's, N* TB, SLP Intake/Headers/Catback, F-body brakes, KYB AGX, Aeroforce, AEM, 93 octane.
  8. #8 Re: Aeroforce full install
    Jul 2010
    Coquitlam,BC,Canada
    Red or pink?
    Pink.
    Yes and yes.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  9. #9 Re: Aeroforce full install
    Kentucky
    Quote Originally Posted by Tonkin2000GT View Post
    It is an '03. A pic would help if you have one.
    I also don't plan on ever having a HUD, wouldn't there be a plug there that would work?
    2003 Grand Prix GT
  10. #10 Re: Aeroforce full install
    Jul 2015
    Jamestown, NY
    I'll go take one you have to open the glove box and squeeze the sides and pull the glove box down passed the stoppers. I don't have hud the plug was tapped to the wire harness.
  11. #11 Re: Aeroforce full install
    Jul 2015
    Jamestown, NY
    It's the pink wire that you want to hook it to the plug is like 10 bucks from zzp. I just didn't want to splice into my wire harness you could do it that way to.
  12. #12 Re: Aeroforce full install
    Kentucky
    Awesome, thanks!
    Any idea what that plug is for?
    2003 Grand Prix GT
  13. #13 Re: Aeroforce full install
    Jul 2015
    Jamestown, NY
    Yea no problem it's just a spare plug that runs to the fuse box most cars have them people just don't know about it.
  14. #14 Re: Aeroforce full install
    the power drop is so close to the fuse box and a add a fuse is way cheaper.
    dont buy that power drop pig tail from zzp if you feel the need, im sure its a 10 dollar ebay thing and zzp marks it up to 20 or 30 i bet.
    you could also cut the plug off and solder or make your own plug for mere dollars. you know like a 3 dollar box of male and female plug ends.
  15. #15 Re: Aeroforce full install
    Jul 2015
    Jamestown, NY
    Here we go with ScottyDoggs cheapness lol it's literally 10 bucks it cost 15 shipped so you don't have to splice into the wire harness. It's really far up in there it makes it easy to just solder it up outside of the car and plug it in.
  1. aeroforce interceptor install help
    By bwc1987 in forum General Tech Discussion
    Last Post: 11-13-2013, 01:05 AM
  2. Aeroforce gauge install
    By scootcoupe91 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-01-2013, 01:41 PM
  3. Aeroforce Install
    By ROTTMAN in forum Visual/Body Modifications
    Last Post: 03-27-2009, 06:42 PM
  4. Full Size Intercooler Install
    By GRANDPRIXFOOL01 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-26-2009, 12:38 AM
