Thread: Extreme loss of power when placed into gear
Results 1 to 12 of 12
  1. #1 Extreme loss of power when placed into gear
    May 2016
    Illinois
    Hey guys im new here an u guys have lots of good info an im sure someone on here has the answer im looking for
    so lets start with my question i have a an 01 gp gt that when placed into gear bogs down to the point where i cant get it to go over 25 mph i had it on jack stands an it did basically the same thing i have changed crank an cam sensor pvc valve cleaned maf changed fuel an air filters and ran it with the cat off just for good measure it had started seeming to lose some power a month ago an started doing the zero out on the rpms an occasionally at about 45 mph I would feel it jerk also changed trans fluid filter an checked fuel pressure is at 45 on idle an rises when placed into gear if anyone has any info would be so greatly appreciated im going bonkers on this on
    sorry for the rambling you guys are awesome
  2. #2 Re: Extreme loss of power when placed into gear
    So it idles and rev's freely when not in gear right but only when the transmission is engaged the car doesn't want to move?
    That does seem odd.
  3. #3 Re: Extreme loss of power when placed into gear
    May 2016
    Illinois
    i suppose it revs poorly all the time now it was reving with no hesitation but not anymore it starts right up an idles fine even if i start throttling it in park it sounds like its sucking air an just runs like garbage while in gear
  4. #4 Re: Extreme loss of power when placed into gear
    it had a tune up at all? other then that im at a loss, you seem to have covered more bases then needed.
  5. #5 Re: Extreme loss of power when placed into gear
    May 2016
    Illinois
    It started with the camshaft sensor code an knock sensor fixed cam sen then went to crank after I replaced crank sen it became basically un drivable also it did say missfire 1-4 at first but as of now no codes no lights nothing an i don't have the funds to send it to a garage to parts change for me
  6. #6 Re: Extreme loss of power when placed into gear
    May 2016
    Illinois
    No tune up beside what was said i am planning on changing plugs probably tonight or tomorrow night just as another to cross off the list as well as being about do also hadn't mentioned but it has 115000 on it
  7. #7 Re: Extreme loss of power when placed into gear
    you could have a bad coil, or icm with the misfire code.
    that cam /crank to icm harness is also known to go bad. mine was all torn up, bare wire showing even.
    you got the crank sensor tq'ed right? its 13 inch pounds iirc.
  8. #8 Re: Extreme loss of power when placed into gear
    Quote Originally Posted by NROBINSON67 View Post
    with only 115,000 on it its likely never had a tune up, change the plug wires too, get iridium plugs, GAP TO 0.60. NO PLATS. CAR WILL HATE THEM.
  9. #9 Re: Extreme loss of power when placed into gear
    May 2016
    Illinois
    I actually swapped the coilpack from another motor an nothing changed i did not tighten to 13 inch pounds though i had just snugged it
  10. #10 Re: Extreme loss of power when placed into gear
    you might want to re do that, its makes a difference, heres the how to, its 13 fp. http://www.grandprixforums.net/threa...a-crank-sensor
  11. #11 Re: Extreme loss of power when placed into gear
    May 2016
    Illinois
    I will have to check the harness when i get home obviously it connects cam crank but where to from there i am not positive where the icm is located
  12. #12 Re: Extreme loss of power when placed into gear
    iirc it leads tot he large square plug near the coil bracket in the lim, it also has a ground wire near the coil bracket where its bolted down.
    the harness tends to fail where it splits and where its tucked in under the water pump.
    this was how mine looked when i took it out. if you zoom in, you can see all the wires are chewed up looking.
  1. Power Loss
    By Stinkygrub in forum Engine
    Last Post: 07-20-2021, 09:11 PM
  2. Philips Extreme Power Bulbs
    By SF9777 in forum Off Topic Discussion
    Last Post: 10-26-2012, 03:51 PM
  3. Need Help! Loss of Power
    By 01GTLAK in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-08-2012, 03:41 PM
  4. power loss
    By gtpsleeper in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-25-2011, 01:16 AM
  5. another loss of power :S
    By ChdMcD in forum General Tech Discussion
    Last Post: 07-31-2010, 07:08 PM
