Thread: HVAC Controls, A/C button won't toggle A/C on
Results 1 to 9 of 9
Z28 HVAC Controls, A/C button... 05-18-2016, 08:38 AM
Fivefingerdeathpunch Re: HVAC Controls, A/C button... 05-18-2016, 10:14 AM
Z28 Re: HVAC Controls, A/C button... 05-18-2016, 11:14 AM
Fivefingerdeathpunch Re: HVAC Controls, A/C button... 05-18-2016, 11:41 AM
Z28 Re: HVAC Controls, A/C button... 05-18-2016, 11:54 AM
Bronco Boy Re: HVAC Controls, A/C button... 05-18-2016, 04:14 PM
Z28 Re: HVAC Controls, A/C button... 05-18-2016, 07:08 PM
Bronco Boy Re: HVAC Controls, A/C button... 05-18-2016, 10:42 PM
Drive XR7 Re: HVAC Controls, A/C button... 05-20-2016, 03:15 PM
  1. #1 HVAC Controls, A/C button won't toggle A/C on
    GT Level Member Z28's Avatar
    Oct 2008
    Omaha, NE
    Has anyone had this issue before?
    I was wondering if just replacing the whole unit is easy to do because I found one on ebay, or does this have little to nothing to do with the issue?
    This is the same unit in the car:
    http://www.ebay.com/itm/C5J2-99-00-P...lV-vHg&vxp=mtr
  2. #2 Re: HVAC Controls, A/C button won't toggle A/C on
    Have you checked other parts of the system before you jump straight to the hvac controller?
    Does the a/c compressor have power, is the relay still good??
    Does the system still have enough freon to kick the system on?
  3. #3 Re: HVAC Controls, A/C button won't toggle A/C on
    Oct 2008
    Omaha, NE
    Can you explain your thought process on the other items? I will explain mine:
    If there was a problem in another area of the A/C system, I would figure the A/C light would turn on, but the system simply wouldn't work. Also, the item is rather easy to change and not expensive, so that was my logic to start there.
    Now as far as the a/c compressor having power. I don't know that, don't know where to check, but do have a voltage meter. The freon should be full since I filled it last summer and has been working all year up to now.
  4. #4 Re: HVAC Controls, A/C button won't toggle A/C on
    I didn't know that the light isn't turning on, I figured you press the button but nothing happens. A slim chance the bulb inside there is burnt out.
  5. #5 Re: HVAC Controls, A/C button won't toggle A/C on
    Oct 2008
    Omaha, NE
    The bulb light is intermittent. Maybe it is burning out? I press it and it kinda turns on, but by the time the button decompresses, it's not lit.
    Pretty sure the A/C wasn't working either way, but I'll be sure of it after work today when it's warmer.
  6. #6 Re: HVAC Controls, A/C button won't toggle A/C on
    Jul 2010
    Coquitlam,BC,Canada
    Does the fan work? All speeds?
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  7. #7 Re: HVAC Controls, A/C button won't toggle A/C on
    Oct 2008
    Omaha, NE
    Quote Originally Posted by Bronco Boy View Post
    Yeah everything else was working fine.
    I tried it again on the way home and everything worked properly. Hoping it's a fluke, but I'm sure it isn't, maybe the switch is going out.
  8. #8 Re: HVAC Controls, A/C button won't toggle A/C on
    Jul 2010
    Coquitlam,BC,Canada
    Quote Originally Posted by Z28 View Post
    That is my thought also. Hopefully it is a fluke. LOL
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  9. #9 Re: HVAC Controls, A/C button won't toggle A/C on
    SE Level Member Drive XR7's Avatar
    Cleveland, OH
    I have a similar issue. The LED or wiring of the LED is loose. If I press on the surrounding area of the button it lights up. Does not affect the use of the a/c though.
    Jason
    2001 Bronzemist Pontiac Grand Prix GTP - SOLD!
    2003 Sonic Blue SVT Mustang Cobra Convertible #2421 (1 of 340)
    2013 Ruby Red Ford Edge Limited EcoBoost
  1. Wtb hvac controls 01-03 analog dual zone
    By Frosty in forum Wanted To Buy - Parts
    Last Post: 11-21-2014, 01:11 PM
  2. Hvac controls???
    By 94grandprix in forum General Grand Prix Discussion
    Last Post: 06-05-2013, 05:49 PM
  3. HVAC Controls
    By Below Average Joe in forum General Tech Discussion
    Last Post: 09-27-2011, 07:26 AM
  4. Bulbs Out In HVAC Controls?
    By ljmonnin12 in forum Audio, Security & Visual Electronics
    Last Post: 11-17-2010, 09:50 AM
  5. HVAC Controls
    By Brads01GP in forum General Tech Discussion
    Last Post: 03-08-2010, 11:49 PM
