Thread: 98 GTP motor to 2002 SE body that had a 3100 motor
Results 1 to 2 of 2
  1. #1 98 GTP motor to 2002 SE body that had a 3100 motor
    Apr 2016
    Dalton, GA
    I have both motors and trannys out looking at what I need to swap over so here are my questions.
    1 Engine bay fuse box, took engine harness out with the 98 motor use the 98 fuse box in 2002 body or stay with 2002 fuse box.
    2 Rack and pinion 98 has wires going to it from the engine harness 2002 does not, do I need that wire or do I have to swap out the rack, better to do it when I have the motor out if needed. I know I have to swap the power steering pump and lines to the 2002
    3 need to swap AC compressor and lines 2002 had no pressure when I took the lines off do I need to have it evacuated before I charge it with Freon.
    4 fuel lines and the vacuum line that goes to the back top of SC need to swap over how do you get the plastic lines off and on the steel lines, can compression fitting be used on the steel lines to make the swap.
    5 Fuel pump need the 98 to go with the motor is there any wires I will need to add for the 2 speed fuel pump that the 2002 will not have.
    Thanks for the help and if I have left something out let me know so I can do it before I drop the motor in next weekend.
  2. #2 Re: 98 GTP motor to 2002 SE body that had a 3100 motor
    likely be best to get a 2002 3800 engine harness, then of course you'll need a pcm to run it in a 02 with a l67.
    grab a tb and maf from a 02. or in the canned tune you need have it changed to a 98 maf file. take your map sensor off the 98 and swap the pig tail if you end up with a na harness vs a sc harness.
    your car dont have magna steer so its never gonna work in the 02 car.
  1. 5 bad push rods / rockers on 48,000 motor 2002 ssei
    By sseilmnop in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-17-2014, 09:21 PM
  2. 98 motor into 97 body need help
    By STEVEGTX in forum Introductions/Noob Questions
    Last Post: 10-23-2012, 07:27 PM
  3. 2002 Regal GS motor/trans swapped into a 97 GTP??
    By toast in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-10-2009, 11:05 PM
  4. 94 GP with 3100, builing motor, want mods
    By 94b4u in forum 3.1L V6 (LHO/LG8)
    Last Post: 06-06-2009, 02:39 AM
