Thread: Racetronix 255lph Conversion
Results 1 to 2 of 2
  1. #1 Racetronix 255lph Conversion
    GTP Level Member
    Pittsburgh
    When you have a H body, but the need more fuel is life, you have to adapt.
    To install most of the High Volume Pumps on the market, the conversion to venturi is needed. why, it fills the canister with fuel instead of relying on the level in the tank to fill the bucket. this keeps the Pump Cool at all times, even when your fuel level in the tank is really low.
    Here are some pics of the buckets and the differences/similarities.
    First off the make this work in the Bonneville, you need a complete canister assembly out of a Buick Park Ave L67, and it has to be a 99. There used to be a old write up along time ago from Tommy Glover on the swap but I think its gone.
    Any way the 99 L67 PA bucket is Venturi, and is a direct swap in for the 00+ Bonneville, and will allow the use of the Racetronix Pump.
    In all the pics that follow the OEM 2003 Bonneville Bucket is on the Left, 1999 Park Ave Bucket on Right
    Differences in the way the strainer attaches to the Bottom
    Tops are exactly the same
    Height is exactly the same
    Arrangement inside, only difference is the 1/8th hose that goes from the pump to the bucket to fill the canister
    I had to purchase a new strainer, and this one is actually for a 2000 Chevy Blazer, but fits and works great.
    Plus the old one had seen better days
    so basically your using a pump that was designed for a 98-02 F body, made for a W body, in a Canister for a Buick Park Ave in a Bonneville......
    2003 SSEi,
  2. #2 Re: Racetronix 255lph Conversion
    SE Level Member bcmonzai's Avatar
    Surrey, BC
    I would think 99' L67 Park Avenues are getting hard to find. The PA venturi pump canister looks similar to my 2000 GTP except for the fuel-level float mechanism. Maybe all you need to do is transfer over the float and arm. Here are some pics of mine for comparison sake:
    http://s1230.photobucket.com/user/bc...20and%20Rewire
    A couple tips on the Racetronix swap:
    1. Make sure the hose clamp is super tight or else it will bleed off pressure. After key-on prime, it should hold 48psi or better for a minute. It took me a couple tries to get it to not bleed off including buying another hose clamp.
    2. Replace the fuel canister o-ring, AC Delco G23, or else you'll get constant evap symptoms and large negative fuel trims. With a new o-ring, it may seem impossible to get the fuel canister seated again into the tank. Make sure the canister is square to the fuel tank and push real hard. Once seated properly, you shouldn't need to hold the pump down to insert to retaining C-clip.
    Addam
  1. Racetronix 255 and racetronix rewire
    By SnowFlake in forum For Sale - Parts
    Last Post: 05-26-2014, 08:38 AM
  2. 255lph without Hotwire swap?
    By Beelzeboul in forum General Tech Discussion
    Last Post: 09-19-2012, 08:54 AM
  3. 255lph pump group buy!
    By Tengis in forum Group Buys
    Last Post: 09-20-2011, 06:15 PM
  4. Walbro 255lph GSS340 pumps 90.00
    By Rocket468 in forum Group Buys
    Last Post: 12-07-2009, 07:46 PM
  5. Venturi modification of Walbro 255LPH
    By Lysander in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-08-2009, 01:49 PM
