Thread: Clanking sound when shifting
Results 1 to 13 of 13
  1. #1 Clanking sound when shifting
    Apr 2011
    North Los Angeles
    When I am reversing out of the drive way and put the car on drive I hear a clanking noise when it begins to move forward, happens almost every time. Has anyone else had this noise, it's really annoying.
  2. #2 Re: Clanking sound when shifting
    motor mounts come to mind, not sure if you re used your old ones or not.
  3. #3 Re: Clanking sound when shifting
    Apr 2011
    North Los Angeles
    I did re use the same ones. Not sure how that would cause one single clanking sound after the car is shifted into drive. Its a single clank as soon as i take off but only happens when the car is backed up then goes forward.
  4. #4 Re: Clanking sound when shifting
    hard to say, vid time.
  5. #5 Re: Clanking sound when shifting
    Jul 2010
    Coquitlam,BC,Canada
    It could be lots of things, mounts for sure. I have never had a clunk, change right CV shaft, get random clunk. Thus why I hate changing OE parts. LOL
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  6. #6 Re: Clanking sound when shifting
    Apr 2011
    North Los Angeles
    I'll record the noise tmrw morning, thanks guys.
  7. #7 Re: Clanking sound when shifting
    hangover park IL
    It's possible it's the brake pads in the caliper bracket.
  8. #8 Re: Clanking sound when shifting
    Apr 2011
    North Los Angeles
    I tried picking up the noise but it wasn't loud enough. I did however notice that the noise occurred when I turned the wheel to the right BEFORE even shifting to drive. I tried recreating the noise but it seems to be evading me now. So a quick break down, I back up, turn wheel to right ready to pull into drive and I hear a clank/popping sound.
  9. #9 Re: Clanking sound when shifting
    Apr 2011
    North Los Angeles
    I forgot to mention i have a busted ball joint on my passenger side, i doubt this could be it though?
  10. #10 Re: Clanking sound when shifting
    Jul 2010
    Coquitlam,BC,Canada
    Quote Originally Posted by steelholder View Post
    There's your problem.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  11. #11 Re: Clanking sound when shifting
    busted ball joint you say? nah that cant make a clunk sound.....change that asap before you crash the car. and yes it can clunk all over town.
  12. #12 Re: Clanking sound when shifting
    Apr 2011
    North Los Angeles
    Yeah i just expected it to make the sound over bumps or uneven roads, not when turning the wheel after reversing?lol, i guess i got a job to do this weekend.
  13. #13 Re: Clanking sound when shifting
    Apr 2011
    North Los Angeles
    Quick update, I got the passenger side joint fixed but thats not where the noise was coming from. In that last few weeks its gotten really loud and it has nothing to do with shifting,its all steering and seems to be coming from the driver side. When i turn the wheel specially at a stand still or very low speeds I hear a loud throbbing clanking popping type noise. It does it a little bit when the cars jacked up and you wiggle the wheel. Everything has been replaced recently lca,bearings even the whole axle shaft, the only thing that I havent replaced this year is the tie rod. Upon inspecting it it seemed fine no leaks anywhere and the outer tie rod seem to have good resistance when i moved it around. Now im doubting this could be it, its hot as hell out and id hate to replace this part if theres something else someone can point out.
  1. Knocking/clanking sound
    By Kellson in forum General Grand Prix Discussion
    Last Post: 04-20-2014, 09:41 PM
  2. Problem shifting to second & scraping sound
    By PaulGoldstraw in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-17-2013, 01:19 PM
  3. Loud Metal Clanking sound
    By klj5022 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-21-2010, 02:05 PM
  4. Clanking Sound
    By TeeWX in forum Tires & Wheels
    Last Post: 07-18-2010, 04:34 PM
  5. Odd issue... Pop/Clunking sound shifting into 2nd OR braking hard...
    By Iron Indian in forum General Tech Discussion
    Last Post: 07-09-2009, 10:28 PM
