Thread: Strange shifting & Idle issue
Results 1 to 20 of 27
Rod2003GT Strange shifting & Idle... 05-01-2016, 01:52 AM
Scottydoggs Re: Strange shifting & Idle... 05-01-2016, 07:27 AM
Rod2003GT Re: Strange shifting & Idle... 05-02-2016, 05:26 AM
BrandonHall10 Re: Strange shifting & Idle... 05-02-2016, 09:26 AM
Rod2003GT Re: Strange shifting & Idle... 05-13-2016, 03:33 AM
Rod2003GT Re: Strange shifting & Idle... 05-15-2016, 03:17 AM
Rod2003GT Re: Strange shifting & Idle... 05-20-2016, 11:54 PM
Turbocharged400sbc Re: Strange shifting & Idle... 05-21-2016, 06:12 AM
Rod2003GT Re: Strange shifting & Idle... 05-21-2016, 08:53 PM
CrazyGuy03 Re: Strange shifting & Idle... 05-21-2016, 06:41 AM
Rod2003GT Re: Strange shifting & Idle... 05-27-2016, 09:50 PM
Rod2003GT Re: Strange shifting & Idle... 05-21-2016, 08:46 PM
Rod2003GT Re: Strange shifting & Idle... 05-23-2016, 02:53 AM
Rod2003GT Re: Strange shifting & Idle... 05-23-2016, 12:42 PM
Rod2003GT Re: Strange shifting & Idle... 06-01-2016, 02:32 AM
CrazyGuy03 Re: Strange shifting & Idle... 06-01-2016, 05:47 AM
Rod2003GT Re: Strange shifting & Idle... 06-16-2016, 04:55 AM
Swiggles Strange shifting & Idle... 06-16-2016, 05:56 PM
Rod2003GT Re: Strange shifting & Idle... 06-17-2016, 09:18 AM
Swiggles Re: Strange shifting & Idle... 06-17-2016, 09:30 AM
Rod2003GT Re: Strange shifting & Idle... 06-17-2016, 10:03 AM
SubwayGuy Re: Strange shifting & Idle... 06-17-2016, 09:46 AM
Rod2003GT Re: Strange shifting & Idle... 06-17-2016, 11:55 AM
Swiggles Re: Strange shifting & Idle... 06-17-2016, 03:35 PM
Rod2003GT Re: Strange shifting & Idle... 06-17-2016, 03:39 PM
Swiggles Re: Strange shifting & Idle... 06-17-2016, 06:28 PM
Rod2003GT Re: Strange shifting & Idle... 06-21-2016, 07:57 PM
  1. #1 Strange shifting & Idle issue
    Quincy, Mass
    You'll need to bring the car to the dealership and have them update the bcm to Pcm by the sounds of it. Or if you know someone local with a tuner have them out a stock file back on your stock Pcm.
    Also check the wires from the tps sensor, they might be frayed or melted somewhere and when they get hot enough they ground out.
    No more GP 04 Impala SS Indy:
  2. #2 Re: Strange shifting & Idle issue
    SE Level Member Rod2003GT's Avatar
    Sep 2015
    CT
    [QUOTE=Swiggles;1432384]You'll need to bring the car to the dealership and have them update the bcm to Pcm by the sounds of it. Or if you know someone local with a tuner have them out a stock file back on your stock Pcm.
    My stock PCM works but doesn't have the latest GM updates. Their is no problem with the ABS or Traction Control when it's installed.
    The TC is inoperable with the ZZP PCM I purchased, which is why they are sending out a replacement.(no charge) Will be here this afternoon.
    2003 Pontiac Grand Prix GT
  1. Strange idle, barely goes, boost gauge maxed
    By nkarasch in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-20-2015, 05:05 PM
  2. Strange engine tic at low idle. Timing chain hardware, valvetrain?
    By KZOO3800 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-14-2012, 07:15 AM
  3. strange issue
    By GTP Push in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-07-2011, 03:16 PM
  4. Help.. Strange Idle (video) after 1.9's/LIM gasket -
    By Brooks in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-15-2011, 06:33 PM
  5. strange issue?
    By GTPJOE90 in forum General Tech Discussion
    Last Post: 06-29-2008, 12:27 AM
