Thread: Strange shifting & Idle issue
Results 1 to 20 of 27
Rod2003GT Strange shifting & Idle... 05-01-2016, 01:52 AM
Scottydoggs Re: Strange shifting & Idle... 05-01-2016, 07:27 AM
Rod2003GT Re: Strange shifting & Idle... 05-02-2016, 05:26 AM
BrandonHall10 Re: Strange shifting & Idle... 05-02-2016, 09:26 AM
Rod2003GT Re: Strange shifting & Idle... 05-13-2016, 03:33 AM
Rod2003GT Re: Strange shifting & Idle... 05-15-2016, 03:17 AM
Rod2003GT Re: Strange shifting & Idle... 05-20-2016, 11:54 PM
Turbocharged400sbc Re: Strange shifting & Idle... 05-21-2016, 06:12 AM
Rod2003GT Re: Strange shifting & Idle... 05-21-2016, 08:53 PM
CrazyGuy03 Re: Strange shifting & Idle... 05-21-2016, 06:41 AM
Rod2003GT Re: Strange shifting & Idle... 05-27-2016, 09:50 PM
Rod2003GT Re: Strange shifting & Idle... 05-21-2016, 08:46 PM
Rod2003GT Re: Strange shifting & Idle... 05-23-2016, 02:53 AM
Rod2003GT Re: Strange shifting & Idle... 05-23-2016, 12:42 PM
Rod2003GT Re: Strange shifting & Idle... 06-01-2016, 02:32 AM
CrazyGuy03 Re: Strange shifting & Idle... 06-01-2016, 05:47 AM
Rod2003GT Re: Strange shifting & Idle... 06-16-2016, 04:55 AM
Swiggles Strange shifting & Idle... 06-16-2016, 05:56 PM
Rod2003GT Re: Strange shifting & Idle... 06-17-2016, 09:18 AM
Swiggles Re: Strange shifting & Idle... 06-17-2016, 09:30 AM
Rod2003GT Re: Strange shifting & Idle... 06-17-2016, 10:03 AM
SubwayGuy Re: Strange shifting & Idle... 06-17-2016, 09:46 AM
Rod2003GT Re: Strange shifting & Idle... 06-17-2016, 11:55 AM
Swiggles Re: Strange shifting & Idle... 06-17-2016, 03:35 PM
Rod2003GT Re: Strange shifting & Idle... 06-17-2016, 03:39 PM
Swiggles Re: Strange shifting & Idle... 06-17-2016, 06:28 PM
Rod2003GT Re: Strange shifting & Idle... 06-21-2016, 07:57 PM
  1. #1 Re: Strange shifting & Idle issue
    SE Level Member Rod2003GT's Avatar
    Sep 2015
    CT
    Quote Originally Posted by Turbocharged400sbc View Post
    You're going to need to scan the ECU while driving to simulate the condition my guess is you're going to find all sensory inputs going sporadic while it happens probably due to a bad ground somewhere and it's very possible that when the radiator fans/high loads/built up heat at resistance point... are required.
    that it is killing the ground circuit for the ECU and causing a voltage drop which causes all sensor inputs to be wrong.
    Good idea. That's where I'll try next. I know a Trans Specialist about 40 min from me that should have the scanner. Should be acting up by the time I arrive.
    2003 Pontiac Grand Prix GT
  1. Strange idle, barely goes, boost gauge maxed
    By nkarasch in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-20-2015, 05:05 PM
  2. Strange engine tic at low idle. Timing chain hardware, valvetrain?
    By KZOO3800 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-14-2012, 07:15 AM
  3. strange issue
    By GTP Push in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-07-2011, 03:16 PM
  4. Help.. Strange Idle (video) after 1.9's/LIM gasket -
    By Brooks in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-15-2011, 06:33 PM
  5. strange issue?
    By GTPJOE90 in forum General Tech Discussion
    Last Post: 06-29-2008, 12:27 AM
