I did the lower intake gaskets on 02 regal 3800 non supercharged. For some reason I could not get the throttle body bracket that''s mounted underneath, I could not get it off without removing the tps.
I thought this was weird because when I did the lowers on my 2001 prix non supercharged, the bracket slightly hit the tps but it cleared with out being removed. Maybe because the regal has the California emissions pipes etc...
Well anyway I got everything back together cleaned the throttle plate which was very gunked. I put the tps back on once i had everything installed. But it would not install the way it came off. It came of with the throttle completely closed, but now to get the bolts to line up the throttle is slightly open which obviously throws off the idle when first started, then it will start and run normal I guess the computer adjusts.
I have tps code and super high idle upon start up in the morning. The only thing I can think of to do is re clean the throttle plate maybe gunk is holding the plate open I will change the sensor but don't know how if that will change anything......
