Thread: L67 vs l32 shortblocks?
Results 1 to 20 of 36
  1. #1 L67 vs l32 shortblocks?
    GT Level Member fisher580's Avatar
    Jan 2012
    Dyersville, Iowa
    Long story short had a piston decide it wanted a hole burnt threw it . . . Yay me.
    my plan is to pick up a new shortblock, and swap all my stuff over to it with new gaskets obviously, but main reason for wanting a short block is I am going with new cam and valve train in new motor. Now my question is if I can benefit at all from a l32 bottom end vs another l67 bottom end.
    Other er option would be a complete l32 and cam that so I would have a gen 5 blower, but more work tearing it down.
    going in an 01 gtp
    2001 Grand Prix GTP Coupe - Black-SOLD
    -SOLD
    2006 Grand Prix GXP - That Purplish dark red color
    -FWI, DiabloSport Trinity, and Trans. Cooler - - 6.8 @ 208 mph LOL
  2. #2 Re: L67 vs l32 shortblocks?
    the blowers better for sure. and the heads are a tiny bit better on the l32, other then that its the same thing, get what ever's cheaper.
  3. #3 Re: L67 vs l32 shortblocks?
    Jan 2012
    Dyersville, Iowa
    Thanks,
    Well after checking more around me found out that a l32 shortblock is $175, so I figure I'll offer 125 and go from there. We're the rods changed throughout the years? Thought I heard some mention that before.
    And heads I'll open up a bit with a Dremel and polish them up good.
    on a side note though, the good cylinders still had 140-150 compression with 240k miles
    -SOLD
  4. #4 Re: L67 vs l32 shortblocks?
    iirc the l67 l36 engines have stronger rods. is that a running short block? pretty cheap. they ask up to grand for a whole l32 here easy
  5. #5 Re: L67 vs l32 shortblocks?
    Yea that's pretty cheap around here a l32/67 go for 1200-1500 with over 100k on them that's local though. But I can get a low mileage l26 shipped here for less then half of that.
    Sent from my KYOCERA-C6745 using Tapatalk
    04 Comp G.
  6. #6 Re: L67 vs l32 shortblocks?
    Jan 2012
    Dyersville, Iowa
    A complete l32 with blower thief getting 900 - 1500, this is just the lower end
    i need to call to arrow to see what is all taken off it.
    Anybody have anything against the XP hot cam? It seems a little more aggressive than intense stage 1 or the vs. but still good with out machining the heads
    -SOLD
  7. #7 Re: L67 vs l32 shortblocks?
    Nothing wrong with the XP except I think that requires the double roller chain setup which seems to be a hit or miss when it comes to quality
    04 Comp G.
  8. #8 Re: L67 vs l32 shortblocks?
    Jan 2012
    Dyersville, Iowa
    What would be best choice then staying away from the double roller? I care about power but the wife wants it to 'sound like a beast'
    the NIC cam caught my attention but people seem to complain about lack of power with them
    -SOLD
  9. #9 Re: L67 vs l32 shortblocks?
    Nov 2015
    missouri
    Can anyone tell me how to tell what engine type I have. I have 2 99 gtp and a 98 gtp
    Sent from my SM-N900T using Tapatalk
  10. #10 Re: L67 vs l32 shortblocks?
    hangover park IL
    l67 is from 97-early 04 where its a transition n to the L32 with the PM rods in mid/late 04
    ~James~ Psychotic Gearhead
  11. #11 Re: L67 vs l32 shortblocks?
    Nov 2015
    missouri
    What about an 04 gt 6th vin digit is a 1
  12. #12 Re: L67 vs l32 shortblocks?
    GTX Level Member Travisgt2's Avatar
    Jan 2013
    leavenworth ks
    L67 series II 3800 v6 with a gen III supercharger. I know that some 04 and all 05+ have better connecting rods in the N/A motors then the 97-03 n/a motors but not sureabout sc motors
    04 GT2: 180 t-stat, cold air intake, reptile tune, plog, hv3, gt1 cam, 90#springs, new push rods, new lifters, port polished heads, lim, uim and tb, 06 Impala brakes and steel brake lines. Cosmetic: black roof rails, under glow, Pontiac ground light, blue hud dic radio controls and cluster. To come custom hood.
  13. #13 Re: L67 vs l32 shortblocks?
    Nov 2015
    missouri
    Would and 04 vin 1 transmission work on a vin 1 99? The 99 is a gtp and the 04 is a gt or gp
  14. #14 Re: L67 vs l32 shortblocks?
    Jan 2013
    leavenworth ks
    If it's sc it will work with little swapping of sensor. That's all I know
  15. #15 Re: L67 vs l32 shortblocks?
    Gear ratios different
    04 Comp G.
  16. #16 Re: L67 vs l32 shortblocks?
    Nov 2015
    missouri
    Even being the same engine code?
  17. #17 Re: L67 vs l32 shortblocks?
    hangover park IL
    Quote Originally Posted by jamesk View Post
    It's the 8th digit not 6th. 04+ would be a 2 or 4. Earlier cars were vin k or 1.
    The only positive way for you to know whether it is an l67 or an l32 is to look at the connecting rods to see if they are the weaker 04+ powdered metal or the earlier more ductile cast rods.
    04 is a transition year....if it's late 04 production date...its more likely to be a PM rod engine.
  18. #18 Re: L67 vs l32 shortblocks?
    hangover park IL
    Quote Originally Posted by Travisgt2 View Post
    you can snap an L26 PM rod just by dropping it on the floor
    pm rods are not better, they are cheaper, which to the beancounters means "better"
    ever hear of "fractured cap technology? yeah, the PM rods are "cracked" apart at the parting line...that is due to the grain structure/brittleness of the PM rods. cant do that to a cast rod, it would just bend. yes fractured caps do remove fretting as an issue, however unless the fracture was "perfect" and assembled properly after initial fracture and then installed in the engine. if not then they likely mashed part of the molecule to molecule interface at the fracture point....so now the rod doesnt clamp properly.
    but hey a PM rods cost less to make, costs less to machine (PM rods are sometimes refered to as "near net weight forging") since the PM rod is "prettier" and more consistent from one to the next.
    its all the luck of the draw, but newer is not always better.
    as for the heads...not always 04+ are more likely to have a good mold number as they retired alot of molds that were heavily core shifted due to reworking the sand molds
    valves are actually ****tier machining at the stem cap.
    remember also that these are all machined on some of the same tooling that machined the old 70/80's 3.8 it was old even in 96, it was damn near broken by the time the 3800 production run was extended in 06 to go to 09
    look at the indexing of the main bearing passages to the intersection of the cam bearing shell. earlier engines were far more consistent, the new ones....you might be lucky, or you might not but i wouldnt run thicker than 5w30, ever with the possibility that passage is only .090 wide past the bearing shell.
    worn table indexer/locks are a *****
  19. #19 Re: L67 vs l32 shortblocks?
    Nov 2015
    missouri
    04 vin is a 4 and I was wrong, I have 2 98 gtp vin x and 1 99 gtp vin w...
  20. #20 Re: L67 vs l32 shortblocks?
    hangover park IL
    it seems yer not starting or seeing the first digits, with a W body car, the 10th digit is always a W, g/h body will be g or h in the 10th spot, look two to the left, it will either be a K or a 1 for a 3800 powered car. i cant remember the vin for the 3100/3400v6.
    both of those gtp's should have a 1 in the 8th spot
