Thread: Removing impossible blower motor resistor
Results 1 to 8 of 8
  1. #1 Removing impossible blower motor resistor
    Mar 2016
    Michigan
    This is an impossible task!!!
    I have a 2002 Grand Prix GTP and I need to replace the blower motor resistor. I took the motor/fan assembly out, and then I unscrewed the 7/32 screw from the connector in front of the resistor only to find that there was another screw behind it the connector! After slicing some sound insulation matting behind the carpet and nearly 2 hours of work, I was able to get the second screw out of a near impossible to reach place. Then I couldn't pull it out and discovered that there was a third screw in an even more difficult to reach location!! I was just wondering if and how anybody else completed this task.
    Perhaps I'm unknowingly trying to take apart the wrong part? In the pictures, the perspective is under the glove box and looking up and frontward. The first picture is a close up of the thing I am trying to take off to get to the blower resistor. Is that correct? In the second picture, I have a socket screwdriver wedged back where there is a screw much deeper.
    In total, there is one screw in the back (the side closest to the passenger seat) and two seemingly inaccessible screws hidden in the front (the side closest to the engine).
    Any advice? I'm almost tempted to just rip out the unit and use the two screws I already got :/
    Removing impossible blower motor resistor Attached Images
  2. #2 Re: Removing impossible blower motor resistor
    Oct 2013
    michigan
    i used a u-joint on a 1/4" drive ratchet. took me 30min to replace the blower motor and resistor.
    01 gtp SD headers. gen V swap. hai. zzp 1.0 pcm. 06 Impala brakes. GMPP sway bar.
    01 ram 2500 870hp/1796lbft fmw s467.7 w/n20 old. new 66/86 compounds ????hp/????lbft.
  3. #3 Re: Removing impossible blower motor resistor
    Mar 2016
    Michigan
    Quote Originally Posted by jlbayes View Post
    Oh okay. Is this a u-joint?
  4. #4 Re: Removing impossible blower motor resistor
    Oct 2013
    michigan
    yes sir.
  5. #5 Re: Removing impossible blower motor resistor
    Mar 2016
    Michigan
    Alright, great! I can see how that would work! Ill try that later. Thank you!
  6. #6 Re: Removing impossible blower motor resistor
    SE Level Member Drive XR7's Avatar
    Cleveland, OH
    This was the first thing I replaced when I bought my used GTP. Did it in a parking lot in 20* weather.
    Jason
    2001 Bronzemist Pontiac Grand Prix GTP - SOLD!
    2003 Sonic Blue SVT Mustang Cobra Convertible #2421 (1 of 340)
    2013 Ruby Red Ford Edge Limited EcoBoost
  7. #7 Re: Removing impossible blower motor resistor
    Mar 2016
    Michigan
    Dayum. You deserve an award!
  8. #8 Re: Removing impossible blower motor resistor
    Enfield, CT
    It's a ***** but can be done. Some people remove the blower motor for easier access.
    You should try to do this with a hangover. It's great!
  1. Replies: 2
    Last Post: 01-15-2014, 11:43 AM
  2. What blower motor and resistor
    By jc71corvette in forum Introductions/Noob Questions
    Last Post: 07-04-2013, 05:59 PM
  3. blower motor resistor?
    By 04silverprix in forum General Grand Prix Discussion
    Last Post: 01-08-2013, 12:02 PM
  4. POOR BLOWER MOTOR AIR FLOW (resistor and blower motor already replaced)
    By jsmit162 in forum Introductions/Noob Questions
    Last Post: 11-06-2012, 10:22 PM
