Thread: Tried everything for this misfire
Page 1 of 3 123 LastLast
Results 1 to 20 of 47
  1. #1 Tried everything for this misfire
    GT Level Member Dadkota's Avatar
    Feb 2014
    Rhode Island
    Some of you may have seen my thread from a few weeks ago about fixing a misfire. Well here is the update:
    Plugs- new
    Wires- new
    Coilpack- new
    Injector- replaced with tested good one
    Cleaned every connection I could possibly relate to the issue.
    No boost/vacuum leaks
    Car is still misfiring when it sees any boost at all, runs great under non-boost conditions though. This Saturday I'm gonna replace the ICM in hopes that it's the issue. Any input?
    '01 GP GTP- Intake, Plog, 3" DP and Exhaust, DHP tuned by me, GMPP sway bars, 3.5 MPS, cold plugs and tstat
    -180,000 miles and climbing
  2. #2 Re: Tried everything for this misfire
    GTP Level Member Tonkin2000GT's Avatar
    Jul 2015
    Jamestown, NY
    Did you do a compression check?
    Sent from my SM-G920V using Tapatalk
    00 Grand Prix GT, top swapped, .020 FMP, GT1 Cam, SFI Crank pulley, SSM90, 3.3 MPS, ZZP ported Gen 3/LIM, ported heads, #90's, N* TB, SLP Intake/Headers/Catback, F-body brakes, KYB AGX, Aeroforce, AEM, 93 octane.
  3. #3 Re: Tried everything for this misfire
    Feb 2014
    Rhode Island
    Yes! Knew I was forgetting something, I checked compression and it tested perfect!
  4. #4 Re: Tried everything for this misfire
    Feb 2014
    Rhode Island
    Its only cylinder 1 btw
  5. #5 Re: Tried everything for this misfire
    Jul 2015
    Jamestown, NY
    Weird
  6. #6 Re: Tried everything for this misfire
    Feb 2014
    Rhode Island
    Tell me about it lol driving me insane!
  7. #7 Re: Tried everything for this misfire
    Jul 2015
    Jamestown, NY
    How much boost are you running ? Is the car stock?
  8. #8 Re: Tried everything for this misfire
    what plugs you use?
    icm could be bad, or a bad wire some where.
  9. #9 Re: Tried everything for this misfire
    Feb 2014
    Rhode Island
    Wires were tested and found good, TR6 plugs that are 300 miles old.
    Car isn't stock but the car was driving great before like 3 weeks ago. No new mods were added, 3.5 pulley btw.
    I compression tested and checked plugs to make sure I didn't chip piston or have carbon buildup on valves
  10. #10 Re: Tried everything for this misfire
    are you using a real plug socket? time to time the porcelain cracks during install of the plugs if you use a normal socket.
    and by wire i mean one from the cars harness, like a injector wire or a wire near the pcm. things can rub through.
  11. #11 Re: Tried everything for this misfire
    Feb 2014
    Rhode Island
    Yea I use a plug socket, I try not to be a hack as much as possible haha the only thing I didn't put the multimeter on is the injector lead. I ohmed the injectors themselves but didn't test the leads going to them. It's just so weird that it fires fine under normal conditions but skips in boost. The only other things I can think of is bad ICM or a bad wire giving reduced voltage to the plugs/injectors
  12. #12 Re: Tried everything for this misfire
    you 100% sure the wires are on right? sh it happens lol
    what are the plugs gaped at? this start after or before the plug change?
  13. #13 Re: Tried everything for this misfire
    Feb 2014
    Rhode Island
    Plugs are at .55 gap, but this problem was actually worse before plug change. Plugs helped a bit, any chance it could be a glitch in the PCM?
  14. #14 Re: Tried everything for this misfire
    Feb 2014
    Rhode Island
    Do you mean plug wires? Lol yes I'm 100% sure they are on right hahaha
  15. #15 Re: Tried everything for this misfire
    you can also look around for a rubbed wire, the metal loop at the dog bone that hols the harness, near and to the pcm, injector harness icm harness and the likes.
    ive ran those plugs for like 20 miles, went to al 104's gaped to 0.50, car loves them so much better.
  16. #16 Re: Tried everything for this misfire
    Feb 2014
    Rhode Island
    Really? See my car likes the TR6 wayyyy more! Next Saturday imma get an ICM from the junkyard and start looking for freyed wires I guess lol
  17. #17 Re: Tried everything for this misfire
    you need to play the gap game with any plug till you feel whats seems best. i gaped em at 60 then 55 then 53 then 50.
    nothing felt as good as the 104's gaped to 50, did the same drill with both plugs.
    yes thats a lot of plug pulling. and it kinda sucks.
    either way, unless the plug is cracked i cant see the brand or temp being the misfire.
  18. #18 Re: Tried everything for this misfire
    Feb 2014
    Rhode Island
    I just can't figure it out for the life of me, almost to the point of just buying a new GP lmao
  19. #19 Re: Tried everything for this misfire
    Jul 2015
    Jamestown, NY
    I'm pretty sure I have a extra ICM laying around from when I did my top swap
  20. #20 Re: Tried everything for this misfire
    Feb 2013
    37.295091, -121.930053
    did you try throwing the kitchen sink at it? all joking aside i hope you get it fixed
    im a cookie again yay me
    please learn to forum better.
    ^^new favorite quote
  1. Misfire
    By Comp04 in forum General Grand Prix Discussion
    Last Post: 11-20-2012, 12:46 AM
  2. Misfire
    By Teddyb in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-20-2012, 12:28 AM
  3. Misfire?
    By blackflag in forum General Tech Discussion
    Last Post: 03-14-2012, 09:41 AM
  4. Very Bad Misfire
    By SDGTP99 in forum General Tech Discussion
    Last Post: 05-12-2010, 09:17 PM
  5. Cylinder #1 misfire and random cylinder misfire
    By whodat79 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-21-2010, 07:16 AM
