Thread: Car stalled while idling?
Results 1 to 4 of 4
  1. #1 Car stalled while idling?
    Sep 2015
    Lansing, Michigan
    Had car since August. I have service records for new spark plugs, plug wires, fuel filter, battery, that were done in 2013.
    Ive had a random lumpy idle issue that occurs every maybe 5-8 starts. Car would fire up, engine would kinda stumble and then smooth out after a split second. Then once at work I went to start it, and it cranked for about 10-15 seconds before firing up - this was back in september. Then maybe 3 weeks ago, I had an extended no crank start that last 10 seconds again but fired right up. The car has lots of power. doesn't have any issues running.
    So a few weeks ago I ordered a new FPR on ebay (yes I know). I installed it, had it in my car maybe a week, and then the car died last night in the snow storm in a parking lot parking spot. I pulled the vacuum line on the new FPR and it pissed out gas all over. Luckily I had my old FPR on me so I put it back in and it fired right up and ran perfect. I got a refund from the seller.
    Then tonight while having the old FPR, I was idling in my driveway maybe 10 minutes and the car randomly stalled. Started it back up, and drove straight over to auto zone and picked up a new fpr and put it in. Drove around for a bit, idled it a bit, and it idles at about 800 rpm's. No stalling yet.
    I've cleaned the MAF and IAC. I had a code for the MAP when I got the car and I replaced that sensor and the code went away.
  2. #2 Re: Car stalled while idling?
    Sep 2015
    Lansing, Michigan
    I've also had an issue that has happened maybe 3 times where I would start the car after leaving the gas station or store, and it would immediately just stall after 2-3 seconds of running but then it would fire right back up just fine. Very random.
  3. #3 Re: Car stalled while idling?
    St. Louis
    What year/model are you working on? Have you removed the TB and cleaned it inside/out? They will get carboned up on the backside of the butterfly valve and cause some strange issues. Cleaning the TB on my 00 GT helped a lot of issues I was having.
    What plugs are you running in it?
  4. #4 Re: Car stalled while idling?
    Sep 2015
    Lansing, Michigan
    Cleaned TB in the fall. Running the stock ac delco plugs and delphi wires.
  1. Car stalled
    By tigers40 in forum General Grand Prix Discussion
    Last Post: 07-16-2012, 09:29 PM
  2. car stalled
    By tstaller2005 in forum General Tech Discussion
    Last Post: 05-07-2011, 09:18 AM
  3. All fed up. And stalled.
    By rusty prix in forum General Tech Discussion
    Last Post: 02-11-2011, 10:57 PM
  4. car stalled
    By GTP514 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-22-2011, 02:55 PM
  5. almost stalled
    By GTPgurl in forum General Tech Discussion
    Last Post: 01-07-2011, 09:17 AM
