Thread: Head Gasket talk
Results 1 to 8 of 8
  1. #1 Head Gasket talk
    GTP Level Member
    Pittsburgh
    no I don't have a Head Gasket Problem, but I will be pulling the Heads for some upgrades.
    lets talk about the pros and cons of the Fel-Pro VS the GM OEM/Victor Reinz Head Gaskets.
    its going to be on a build that should make 400+whp, Boost in the 15psi+ range. I will be using ARP Studs
    I have a part number for the GM kit of 89017824 and that (INCLS VLV CVR,INT MANIF,CYL HD GSKTS,INT MANIF TO BLK SEAL)(INT-TO-BLK SEAL HAS 2 LOCATING PINS)(FOR 1ST DESIGN SEE 12538688).
    The Fel Pro Kit includes a lot more Gaskets that I honestly wont use in the Heads/Cam Swap but are nice to have as a backup....
    2003 SSEi,
  2. #2 Re: Head Gasket talk
    Enfield, CT
    Go with OEM. They are proven to be dependable.
  3. #3 Re: Head Gasket talk
    OEM is fine.
  4. #4 Re: Head Gasket talk
    Buffalo
    I'm pretty sure I picked the OEM as well
  5. #5 Re: Head Gasket talk
    Florida
    I've run both, and never had an issue with either. Car currently has a set of Fel-pros. I believe it more to be in the surface prep of the block/head, and proper torquing sequence.
    I'd go with whichever is cheaper, or easier for you to get.
  6. #6 Re: Head Gasket talk
    May 2008
    Schuyler, NE
    Either should be fine.
    I sprayed a 175 shot on stock head bolts and Victor reinz gaskets without any problems. Lots of nitrous, and lots of detonation.
  7. #7 Re: Head Gasket talk
    GTP Level Member Silver2kgtp's Avatar
    Feb 2008
    NY
    I currently have GM gaskets. 25 psi and no issues.
    I've also had MLS and they suck.
    http://s1292.photobucket.com/user/si...d%20Prix%20GTP
    10.99 @ 121.99 1.74 60' (Ran out of fuel : +18 AFR)NO SPRAY!!!
  8. #8 Re: Head Gasket talk
    Buffalo
    I wouldn't and didn't run MLS. Given to me for free and I went the VR / OEM route from rock auto.
  1. Let's talk LIM and UIM gasket leaks
    By Dadillac in forum General Grand Prix Discussion
    Last Post: 04-26-2014, 03:54 PM
  2. Head gasket and head crack questions.
    By deib in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-28-2012, 03:50 PM
  3. cracked head blown head gasket or just done??
    By roytoy70 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-25-2012, 10:40 PM
  4. Help is it head gasket water pump or intake gasket
    By jared71 in forum Introductions/Noob Questions
    Last Post: 02-14-2012, 01:26 PM
