If you keep the pedal setup, than you can keep the Drive by wire, if not I believe you will need to swap over to a 97-03 harness and computer to run a standard throttle linkage ( you will also need a different TB, as there is no cable or linkage provisions on the DBW TB)
If you keep the DBW, it should only be a challeng of wiring up the cruse control buttons to get CC to work![]()
