My 2006 Grand Prix GT lost all power today when I put the key into the ON position. Everything was dead inside and outside the car, wouldn't crank the engine either.
First, a little background. I bought the car from a guy that said it occasionally wouldn't start. I figured it was a key issue and bought the car. I cleaned the battery posts and everything seemed great. I did notice that sometimes when you start the car it reports low voltage, 10.9 on up and will stay around 11.5-12V then climb as your drive to 14ish volts.
Back to the problem I had today. I checked the battery posts first. I left the key in the ON position and started checking things out. 12.3V at the battery at the wires, on the engine(ground) and at the main connection to the power distribution box near the battery. This is wear things get weird. The bottom portion of the power distribution box had 12.3V but the top half had 9.9V. Checked the Interior fuses, a couple were 9.9 but most were 2.3 or less. When checking the voltage at the power distribution box I used the - battery post for the ground.
OK, I figured something was wrong behind the power distribution box so I decided to pull it out. I started to disconnect the battery when the terminal came loose but tapped the ground again and I heard the relays click and saw the headlights flash out. I reconnect it and everything is on. Full power to everything in the power distribution box, 12+ volts. I check the interior and still 9.9-10.1V at the fuses. I pulled the power distribution box and I didn't see anything obvious back there. No scorching, rust, corrosion. Everything was tight.
I'm worried I'm going to be chase this, so I'm hoping you guys have seen something like this before and can same me a bunch of time. Thanks in advance.
