Thread: Borla XR1 Muffeler and no Res?
Results 21 to 40 of 58
  1. #21 Re: Borla XR1 Muffeler and no Res?
    a few ca guys have cut the hole to a 3 inch hole in and out on the factory cat, then welding the headers 3 inch down pipe to the factory cat.
    or you need to find tog, or slp headers, both are carb compliant.
  2. #22 Re: Borla XR1 Muffeler and no Res?
    Quote Originally Posted by silenthaven View Post
    So no power difference at all. Not trying to max out. To be clear this is my set up 104 autolites, 180 tstat, Overkill tune, k&n intake, zzp 3 inch downpipe, powerlog, 3.5 pulley and that pfyc borla catback muffler system. Now the 3 inch catback will do no good or better? Will at least adding XR1 borla mufflers sound better than the pfyc borla mufflers (assuming you have some idea of what they sound like :/) Not trying to sound v8 just trying to sound clean with a bit of volume and intimidation at a v6 level. Current setup sounds only slightly better than probably stock mustangs... idk
    Want more flow.. Get rid of the plog/Dp and go with a set of headers. With your current setup there's no way your out flowing what you currently have.
    The only mufflers from Borla that I've heard on the 3800 are the XS pro (that's what I ran stock and what I still run on my 3" setup). It's slightly louder but that's a giving going from the stock 2.25 to 3" exhaust but I'm also running a large 32" resonator that quiets it down. Only reason I went with 3" over 2.5" is because I got a hell of a deal on the piping and was way cheaper then what the 2.5 piping was selling for.
    04 Comp G.
  3. #23 Re: Borla XR1 Muffeler and no Res?
    Feb 2015
    california
    Quote Originally Posted by ScottyDoggs View Post
    yeah those headers arent friendly on my wallet.
  4. #24 Re: Borla XR1 Muffeler and no Res?
    Feb 2015
    california
    Quote Originally Posted by REDCRAPGP View Post
    yeah im in ca im screwed on getting headers. So i wonder how the xs and xr1 mufflers would compare to my current borla catback and mufflers
  5. #25 Re: Borla XR1 Muffeler and no Res?
    Jul 2010
    Coquitlam,BC,Canada
    Borla's, yes! No resonator, no!
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  6. #26 Re: Borla XR1 Muffeler and no Res?
    YouTube. There a bunch of 3800 guys that run the XS I'm sure you'll find a few videos to compare
    04 Comp G.
  7. #27 Re: Borla XR1 Muffeler and no Res?
    Feb 2015
    california
    how about xr1 cause im more interested in these
  8. #28 Re: Borla XR1 Muffeler and no Res?
    Get to researching
    04 Comp G.
  9. #29 Re: Borla XR1 Muffeler and no Res?
    Feb 2015
    california
    Get to researching
    Thats what im doing. Not much on the xr1s not to mention my question is so specific.
  10. #30 Re: Borla XR1 Muffeler and no Res?
    GTP Level Member Kaiser Pontiac's Avatar
    Jun 2015
    Land of 10,000 Salted Roads and Rusty Cars.
    Quote Originally Posted by Tonkin2000GT View Post
    What exactly does a resonator do? I have a camed/supercharged 3800 with slp headers and slp catback with no resonator or catalytic converter I do know what you mean you can't get it to sound like a v8 but it sounds good it has a deeper rumble to it. It does have a raspy sound when you get on it and let off quick or rev it real high not under load but it's a v6 I've come to the conclusion that there is nothing I can do about it.
    When I found out my muffs were rusted out I thought I'd do some research around the web. From what I read the resonator, the longer the better, helps reduce drone from the exhaust if you have no cat.
    I don't have a cat (or a cat-back for that matter), and I figured for the right price I should just do a res while I'm hacking up a couple exhausts because drone is bleh, and these cars you really do need mufflers. So, I found a cheap solution: buy brand new resonator the right width from a member here for a good price, bought a complete '07 exhaust off of Craigslist with 40k on it for $35, sell cat off of that. Total investment around $35.
    And I just loath that raspy sound when under acceleration then backing off, anythign to avoid/keep that to a minimum I told myself.
    Personally, unless your pushing a metric-ton of power the 2.5" exhaust seems to be just fine. (from what I've read) And unless it's turbo'd and/or cammed then spending anything extra on exhaust on a GP just seemed pointless to me, like spending 1k to try and sound like a V8 as some people do. The only essential thing seems to be getting rid of the restrictive U-bend on the 6th gens. I'd rather spend the money on power mods than exhaust, if I was trying to spend money on this old thing, lol.
    Just my $0.02, from what I've heard(literally, lol)/read. I'm still a noobie though, so pardon me if I got anything mixed up.
    06 LaCrosse 57-79k sold;99 4dr GTP 134-138k sold;98 2dr GTP 183k parted;98 Regal 166-184k;04 GT2 204-206k sold;04 GTP 170-175k sold;09.5 G8 GT Sport 145k;09 G8 78-84k+;08 Prix 164k sold;06 Prix 168k sold;02 Regal 92k;09 G8 103k parted;04 GTP SpEd 139k parted;04 GTP 205k;'09 G8 105k parted;06 Prix 230k;04 CompG 138k
  11. #31 Re: Borla XR1 Muffeler and no Res?
    Yup because 99% go with what's been proving to sound pretty damn good. That's why XS pro come up so much.
    And yes the longer the resonator the better. Kills drone especially that god awful drone you tend to get during deaccleration. It'll never sound like a v8 so don't try to even it to sound like that.
    04 Comp G.
  12. #32 Re: Borla XR1 Muffeler and no Res?
    Feb 2015
    california
    so youre insinuating that the xs pro are better than xr1?
  13. #33 Re: Borla XR1 Muffeler and no Res?
    GTP Level Member Tonkin2000GT's Avatar
    Jul 2015
    Jamestown, NY
    Is the resonator worth having like how much does it fix? I just figured it would restrict the flow so why bother same with the cat.
    00 Grand Prix GT, top swapped, .020 FMP, GT1 Cam, SFI Crank pulley, SSM90, 3.3 MPS, ZZP ported Gen 3/LIM, ported heads, #90's, N* TB, SLP Intake/Headers/Catback, F-body brakes, KYB AGX, Aeroforce, AEM, 93 octane.
  14. #34 Borla XR1 Muffeler and no Res?
    No what I'm saying Is the XS pro have been used on wbody by several several people. Why reinvent the wheel? There's a reason why because they sound pretty damn good. Or you can get a set of those XR1, go through the hassle of welding them on.. And hope that you like it.
    04 Comp G.
  15. #35 Re: Borla XR1 Muffeler and no Res?
    No it's a straight through design, it won't restrict flow. These cars sound like ass without a resonator
    04 Comp G.
  16. #36 Re: Borla XR1 Muffeler and no Res?
    SWPA
    Have you ever seen the inside of a resonator?
  17. #37 Re: Borla XR1 Muffeler and no Res?
    Jul 2010
    Coquitlam,BC,Canada
    After installing my Borla XS's (PO removed resonator), I went about two weeks before the drone made me pull out my hair. No resonator makes a HUGE difference.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  18. #38 Re: Borla XR1 Muffeler and no Res?
    Sep 2013
    Northwest Indiana
    I believe the XR-1 is more of a racing muffler, and is louder than the pro-XS. My favorite sounding set up on a 3800 is a glasspack in place of a resonator, and
    two borla pro-xs mufflers at the rear. It's not raspy at all, and the glasspack gives it a bit of a unique sound too it.
    2000 GTP Daytona 500. Headers, 3.4 pulley, intake, exhaust, KYB AGX,
    W-body store springs, new bushings all around
  19. #39 Re: Borla XR1 Muffeler and no Res?
    It's a 3800.
    It's always crappy sounding.
    You can try and mask it all you want.
    Big resonator, catless headers, and a quiet set of mufflers and larger diameter piping that probably isn't needed is going to net the best exhaust note without a turbo.
  20. #40 Re: Borla XR1 Muffeler and no Res?
    Jul 2015
    Jamestown, NY
    What's the best stainless resonator to use? Does it matter where you put it?
  1. has anyone ran borla on there gxp on here?
    By LSFoFaSho in forum 5.3L V8 (LS4)
    Last Post: 05-09-2014, 06:39 PM
  2. borla vs. zzp
    By Orange04CompG in forum Visual/Body Modifications
    Last Post: 11-24-2013, 11:11 AM
  3. Borla Exhaust
    By GAFF in forum Off Topic Discussion
    Last Post: 03-30-2011, 03:26 PM
  4. Got my Borla's on.
    By rocafella2032 in forum Visual/Body Modifications
    Last Post: 11-23-2009, 11:54 PM
