Thread: Fogs on with High Beams, Someone School Me?
Page 2 of 2 FirstFirst 12
Results 21 to 31 of 31
  1. #1 Re: Fogs on with High Beams, Someone School Me?
    Enfield, CT
    Quote Originally Posted by Bronco Boy View Post
    Around here, the copper could write you up for a Vehicle Inspection, which costs around $120, and could lead to other problems with your vehicle that must be repaired before you pass the inspection.
    Pretty sure I have a better chance of winning the Powerball Lottery. LOL
    Canada is extra anal about vehicle safety so you are kinda screwed.
    Sent from my LG G3
  2. #2 Re: Fogs on with High Beams, Someone School Me?
    Sep 2014
    Worcester, MA
    I have no idea what you're asking, but I guess it would be the same way they prove you run a stop sign or jaywalk. They observe you and write you up.
    I'm just trying to make the OP aware of a potential problem.
  3. #3 Re: Fogs on with High Beams, Someone School Me?
    Enfield, CT
    I understand you are just making him aware of a potential problem but cops hate paperwork so the chances of them giving you trouble is slim. At least around my neck of the woods thats the case
    If you did get in trouble for whatever reason, disable mod and record a video of your lights in stock form and give it to the judge.
    Sent from my LG G3
  4. #4 Re: Fogs on with High Beams, Someone School Me?
    GTP Level Member Tonkin2000GT's Avatar
    Jul 2015
    Jamestown, NY
    You guys are shot if you think cops really worry about your fog lights being on with your high beams smh. It's like my tint is illegal and my exhaust is loud as **** but that doesn't stop people from doing it.
    00 Grand Prix GT, top swapped, .020 FMP, GT1 Cam, SFI Crank pulley, SSM90, 3.3 MPS, ZZP ported Gen 3/LIM, ported heads, #90's, N* TB, SLP Intake/Headers/Catback, F-body brakes, KYB AGX, Aeroforce, AEM, 93 octane.
  5. #5 Re: Fogs on with High Beams, Someone School Me?
    Jul 2010
    Coquitlam,BC,Canada
    Quote Originally Posted by HighOctaneRacing View Post
    Screwed in general, yes. LOL
    I've never had issues with my HID's, fogs, window tint, lifted vehicle etc, but when I did inspections years ago, we had a lot of vehicles busted for all of the above, so it does happen here for sure.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  6. #6 Re: Fogs on with High Beams, Someone School Me?
    Enfield, CT
    Lol shot? Not me. I'm gonna run my HID fogs with my high beams.
    Sent from my LG G3
  7. #7 Re: Fogs on with High Beams, Someone School Me?
    GT Level Member MyHero's Avatar
    Nov 2015
    Laws are only politician scribble. I was never consulted on any of these laws, therefore I pick and choose the ones which I follow
    MyHero is my pet project, not automotive related
    My car is an 00 GTP
  8. #8 Re: Fogs on with High Beams, Someone School Me?
    Jul 2015
    Jamestown, NY
    It stays like that? Is there any way to solder at the base?
  9. #9 Re: Fogs on with High Beams, Someone School Me?
    Jul 2015
    Jamestown, NY
    Okay thanks for the info man I really appreciate it but I took my chances an soldered it luckily it worked. I notched the plastic a little and used as little heat as possible then the little bit of excess solder I sanded off with a dremel and it actually sits in flat and all the way. It sits flatter then the fog light relay that kinda sits lop sided from bending the tab.
  10. #10 Re: Fogs on with High Beams, Someone School Me?
    Jul 2010
    Coquitlam,BC,Canada
    I didn't notch anything, just wrapped the wire around the pin and put the relay back in; been that way for 5 years now and all is good. I tried to solder, but I suck at soldering. LOL
    To do it "properly", remove the fuse box and solder to the corresponding wires on the backside.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  11. #11 Re: Fogs on with High Beams, Someone School Me?
    Nov 2015
    I just drilled a small hole in the base of each terminal, fed the wires through, twisted around the terminal, light electrical tape and reinsert.
    My car is an 00 GTP
  1. High beams will not come on
    By jjaaam in forum General Tech Discussion
    Last Post: 01-28-2016, 02:54 AM
  2. 05 gtp lows beams stay on with high beams.
    By pontiacGTP123 in forum General Tech Discussion
    Last Post: 06-15-2014, 01:24 PM
  3. 04+ low beams plus fogs on at the same time?
    By hockeybawler in forum General Grand Prix Discussion
    Last Post: 09-25-2012, 10:41 PM
  4. high beams.
    By gunsn88 in forum General Grand Prix Discussion
    Last Post: 01-14-2012, 03:44 PM
  5. No High Beams
    By taximech in forum General Tech Discussion
    Last Post: 06-23-2009, 11:37 AM
