Thread: Canned tune question
Results 1 to 7 of 7
  1. #1 Canned tune question
    SE Level Member brokeazfunk's Avatar
    Aug 2013
    Phoenix Az
    In a GTP with the "performance" button on the shifter, when not in performance mode, is it the same as a stock PCM?
    Meaning, the PCM mods don't kick in or activate until I push the button putting it into performance mode, leaving it the same as a stock PCM until that point. Is this correct?
  2. #2 Re: Canned tune question
    SWPA
    The performance button has nothing to do with the ECU tune. It only changes shift points in the transmission between "economy" (lower shift points) and "performance" (slightly higher shift points)
  3. #3 Re: Canned tune question
    GTP Level Member Impala131's Avatar
    Knoxville, TN
    Quote Originally Posted by brokeazfunk View Post
    It all depends on which "canned" tune you have. The performance shift button just tells the PCM to swap a few tables related to shifting to a set specifically for performance shift. The canned tune could leave both sets of tables stock, it could modify just the performance shift tables and leave the standard ones stock (or vice versa) or could modify both tables to be different. It just depends on who did the tuning. This is a question you should direct to the vendor.
    2003 Grand Prix GTP.... the journey begins again....
    E85 Self Tune with HPT, 80# Injectors, Gen V 3.4 pulley, SD Headers, AL605 Plugs
  4. #4 Re: Canned tune question
    Kemmerer, Wyoming
    performance shift button is overrated. I think it was 2001 when the button went away and the pcm tables automatically went to that shifting in power enrichment mode
  5. #5 Re: Canned tune question
    Aug 2013
    Phoenix Az
    Quote Originally Posted by Impala131 View Post
    It is a ZZP 1.0. Nothing real special. I will contact Tim and see what he says. I cant remember what he said about it so I figured id ask yall first.
    The reason im asking is, if I remove the ZZP pcm to send it back to him for updates. Will it hurt to put my stock one back in while i wait?
  6. #6 Re: Canned tune question
    you can run the stock pcm. just dont go beating on it if you have mods till you get the tuned one back.
    i have my per shift set up to shift higher than normal shift.
  7. #7 Re: Canned tune question
    Aug 2013
    Phoenix Az
    Quote Originally Posted by ScottyDoggs View Post
    Thanks for the advise guys.
  1. zzp canned tune
    By hollas13 in forum PCM Tuning
    Last Post: 05-02-2014, 02:02 PM
  2. canned tune
    By hollas13 in forum General Grand Prix Discussion
    Last Post: 01-19-2014, 08:45 AM
  3. should i get a canned tune for the time being?
    By Doug 97 gtp in forum PCM Tuning
    Last Post: 06-09-2013, 03:12 PM
  4. Canned tune question
    By hockeybawler in forum PCM Tuning
    Last Post: 02-26-2013, 08:44 AM
  5. looking for a canned tune
    By KLRADO in forum PCM Tuning
    Last Post: 02-17-2012, 12:14 PM
