Thread: 05 Comp G Cooling issues
Results 1 to 20 of 23
  1. #1 05 Comp G Cooling issues
    GTP Level Member Austins01GP's Avatar
    Nov 2010
    Maryville, MO
    I have a 2005 grand prix comp g and when I get into stop and go traffic, the coolant temp soars up. Last night, 32 degrees outside, the car temp got up to 220 degrees. I have been fighting this issue for a little while and have flushed the cooling system several times then switched to green antifreeze, replaced the thermostat a couple times (180* now) and made sure the fans are coming on.
    The car has never quite made it into the red on the gauge, but I don't think this is nomal, any ideas?
    // 1992 Nissan 300zx Twin Turbo (More RWHP than the Comp G)
    // 2005 Comp G
    CLICK ME!! for my Z Build and Comp G
  2. #2 Re: 05 Comp G Cooling issues
    A blocked radiator or a under performing water pump can cause these issues while not moving.
    Hard to say the exact cause though.
  3. #3 Re: 05 Comp G Cooling issues
    Nov 2010
    Maryville, MO
    I'm gonna change the LIM gaskets soon as im approaching 150,000 miles, might change the water pump while I'm at it and see if that resolves the issue
  4. #4 Re: 05 Comp G Cooling issues
    Nov 2013
    Wisconsin!
    Well unless you also changed the temp the fans come on in the pcm. Your 180 tstat won't do anything for you in stop and go traffic.
  5. #5 Re: 05 Comp G Cooling issues
    Nov 2010
    Maryville, MO
    Yeah I have heard that, i believe fan turn on was around the ~ 208 mark, my fans do come on, but don't seem to be able to control the temperature as the engine continues to get hotter
  6. #6 Re: 05 Comp G Cooling issues
    Factory temp settings are 212 and 226 if I remember right, I'm within 2º atleast.
  7. #7 Re: 05 Comp G Cooling issues
    Nov 2013
    Wisconsin!
    ^this.....the high speed setting doesn't turn on until 226 or someplace around there. So you're actually not running hot.
  8. #8 Re: 05 Comp G Cooling issues
    Nov 2010
    Maryville, MO
    That's just seems so hot to me! Still tho when it's this cold out I would think the low speed setting would be more than enough to hold the car at a lower temperature
  9. #9 Re: 05 Comp G Cooling issues
    cars meant be run at 210 ish. read the temp from the obd port. thats a better reading.
  10. #10 Re: 05 Comp G Cooling issues
    Nov 2013
    Wisconsin!
    Well, again. Since that's what gm programed the fans to turn on at, unless you change it. Your 180 isn't helping anything.
    And if it only does it in stop and go, where you have increased heat and well, you drive a blown 3800, the m90 makes lots of heat. The Temps are going to rise.
    Are you using a scan gauge to read the Temps actually reported or just going off the gauge?
  11. #11 Re: 05 Comp G Cooling issues
    Nov 2010
    Maryville, MO
    Yeah I'm using my scan gauge to read actual Temps. The gauge on the dash will get into the section right below the red area.
    I do understand the fans won't benefit the 180 t-stat, but shouldnt the car temp stay around 212 if the fans are kicking on, the thermostat is is open and it's below freezing out? That's what my concern is especially when it gets hot out again next summer
  12. #12 Re: 05 Comp G Cooling issues
    05 temps are set higher for some reason, like 126 for high speed 118 low speed iirc. i posted a pic of the setting in another thread some time back.
  13. #13 Re: 05 Comp G Cooling issues
    Nov 2010
    Maryville, MO
    Hmm that's strange! Probably gonna use this as an excuse to get a tune lol
  14. #14 Re: 05 Comp G Cooling issues
    Nov 2013
    Wisconsin!
    In stop and go traffic with little airflow. Your car doesn't care if it's below freezing or not.
    If it hasn't overheated and the Temps do come down after the fans kick on. Then why worry? They are doing what they are supposed to.
  15. #15 Re: 05 Comp G Cooling issues
    Nov 2010
    Maryville, MO
    The temp doesn't come down when the fans kick on, that's the problem and the car hasn't overheated because I either shut it off or get out of traffic before it gets up too high
  16. #16 Re: 05 Comp G Cooling issues
    another guy here was trying to figure this all out in his 05 car. same deal, just the fan settings.
    your in MO you should be able to find a tuner local to do the fans for ya. or a full tune even.
  17. #17 Re: 05 Comp G Cooling issues
    GT Level Member JamesIvey24's Avatar
    May 2011
    Illinois
    be sure you're not missing the rubber piece that goes over the top of your condensor and rad. also, reptile should be clsoe to you for a tune.
  18. #18 Re: 05 Comp G Cooling issues
    Nov 2013
    Wisconsin!
    How long have you let it go? Just how hot has it got before you shut it off?
  19. #19 Re: 05 Comp G Cooling issues
    GXP Level Member
    Mar 2015
    Tomball
    Quote Originally Posted by ScottyDoggs View Post
    ^^^This Scotty actually posted this from the .bin file for 05' for me, when no one believed that the fans on 04+ don't come on until 217 for low. This causes the temp to get to about 221-222 until it starts to drop to about 210 then it does it all over again. I posted graphs of the oscillation while sitting in traffic. It's normal don't worry about it. If you want change your fan settings, with a tune.
    Jeff
  20. #20 Re: 05 Comp G Cooling issues
    Nov 2010
    Maryville, MO
    That's very strange heat cycling, and I had reptile tune my old 01 car, but I thought he was out of tuning, I'll message him and find out. And I've let the temp get up too 222ish and thought that was way to high for a car that has a stock 195 thermo lol
  1. cooling issues
    By Jtg1551 in forum General Tech Discussion
    Last Post: 02-12-2013, 01:06 PM
  2. cooling fan issues
    By nakedredneck in forum General Tech Discussion
    Last Post: 12-10-2012, 08:36 PM
  3. Cooling issues?
    By Timing in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-15-2012, 04:37 PM
  4. Cooling system issues.
    By Curt7 in forum General Tech Discussion
    Last Post: 08-15-2011, 12:47 PM
  5. Help me with my cooling issues.
    By Rocket468 in forum General Tech Discussion
    Last Post: 07-24-2010, 07:42 AM
