Thread: Pass steering knuckle
Results 1 to 20 of 21
  1. #1 Re: Pass steering knuckle
    hangover park IL
    ive seen enough broken alum knuckles that we went straight to the steel dormans (beefier than the steel 9c1)
    the way the corrosion pits and expands within a cavity just leaves too many fracture prone points near the edges of a relatively thin alum die casting.
    one of the worst areas for corrosion is between the strut ears and the upper knuckle.
    basically put...there's a reason that GM put the steel knuckles on the HD 9c1/taxi packages
    it took a while before i found nice clean alum knuckles off an 02 that evidently got split outer cv boots early in its life from someone prying on the lower ball joint stud....if id hazard a guess.
    on the other side of the coin... you may just have had a weak knuckle, the number of broken knuckles ive seen is well below a 1per 1k failure rate by a large margin, go to the junkyard and find an cleanish W/G/H body and take the knuckle and you'll likely be fine.
    ~James~ Psychotic Gearhead
  2. #2 Re: Pass steering knuckle
    Jan 2014
    AR
    I know this thread is neatly wrapped up and don't intend to hijack it, but...
    Quote Originally Posted by Turbocharged400sbc View Post
    Steel knuckles? Did not know about those and must investigate. Just fronts? Any fit differences?
  1. Tie rod endlink and steering knuckle question
    By izup69 in forum Brakes/Suspension/Chassis
    Last Post: 10-24-2021, 12:35 PM
  2. 2008 Grand Prix torque for tie rod to knuckle nut
    By daviddawg in forum Introductions/Noob Questions
    Last Post: 11-18-2015, 10:46 PM
  3. Replies: 2
    Last Post: 02-14-2012, 08:47 PM
  4. Steering Knuckle Replacement
    By bjornbjorn in forum General Tech Discussion
    Last Post: 10-24-2011, 06:20 PM
