i have a 04 gp. the key fob is not working right i have to put the unlock button like 10 to make the doors on lock. i have took it apart and cleaned it. its sill doing it. any help would be great.
Same here. Check battery that was my first issue
If I hit the trunk or the panic buttons they work with a push so it must be wore out
Sent from my HUAWEI H892L using Tapatalk
you can glue foil on the under side of the button, or use a paper hole punch and some foil tape, aka duct sealing metal tape. or buy a new button pad for like 5 bucks on ebay.
