Thread: Another way to kill a Hub Bearing
Results 1 to 2 of 2
  1. #1 Another way to kill a Hub Bearing
    GTP Level Member Burbman's Avatar
    Dec 2008
    ****'s Creek
    So on my way into NYC yesterday and as I left the office parking lot I hit a bump and was rewarded with the ABS/trac lite combo. The RF hub bearing was new, so was wondering if it might be the LF, then cursing myself for not changing it when I changed the axle on that side.
    Jacked it up last night in the driveway to check for bearing play and it seemed OK. Decided to pull the wheel and test the sensor with a multimeter, then noticed the wire dangling. The connector had come unclipped from the stand-off bracket by the hub, allowing the wiring to flop around, maybe too close to the spinning axle. The connector was still connected, but the wires were ripped clean out of the hub. So the hub is toast regardless of whether the bearing is still OK or not.
    I always use a zip tie or 2 to make sure that the connector stays attached to that stand-off bracket. The clip on the connector doesn't always clip tight enough for my liking.
  2. #2 Re: Another way to kill a Hub Bearing
    take the busted hub off and take it to the store you got the last new hub from, if your still under warranty you warranty the hub, they got no clue.
  1. Eh, a kill is a kill..
    By JDrach in forum Track Sessions and Kills
    Last Post: 08-27-2014, 11:15 AM
  2. 2012 Eclipse... Kill, 2000 honda civic...kill
    By justinhvr1 in forum Track Sessions and Kills
    Last Post: 02-02-2013, 01:07 PM
  3. ECLIPSE GT.. KILL :) / Mustang Roush..KILL :) / G8 GXP..MURDERED u_u
    By 9ordohz in forum Track Sessions and Kills
    Last Post: 01-31-2013, 04:47 PM
  4. Not too proud of it, but a kill is a kill
    By 98L36 in forum Track Sessions and Kills
    Last Post: 10-09-2011, 10:44 AM
  5. First kill.. TBSS vs my GS kill?
    By chevyy1212 in forum Track Sessions and Kills
    Last Post: 04-25-2011, 06:02 AM
