Thread: help with fob
Results 1 to 5 of 5
  1. #1 help with fob
    Oct 2015
    gwinn mi
    i have a 04 gp. the key fob is not working right i have to put the unlock button like 10 to make the doors on lock. i have took it apart and cleaned it. its sill doing it. any help would be great.
  2. #2 Re: help with fob
    SWPA
    Buttons are probably wore. Had the same issue. Replaced the button pad and all was well.
  3. #3 Re: help with fob
    GTX Level Member Travisgt2's Avatar
    Jan 2013
    leavenworth ks
    Same here. Check battery that was my first issue
    04 GT2: 180 t-stat, cold air intake, reptile tune, plog, hv3, gt1 cam, 90#springs, new push rods, new lifters, port polished heads, lim, uim and tb, 06 Impala brakes and steel brake lines. Cosmetic: black roof rails, under glow, Pontiac ground light, blue hud dic radio controls and cluster. To come custom hood.
  4. #4 Re: help with fob
    Oct 2015
    gwinn mi
    If I hit the trunk or the panic buttons they work with a push so it must be wore out
    Sent from my HUAWEI H892L using Tapatalk
  5. #5 Re: help with fob
    you can glue foil on the under side of the button, or use a paper hole punch and some foil tape, aka duct sealing metal tape. or buy a new button pad for like 5 bucks on ebay.
