Thread: Downpipe bolts not sealing downpipe to manifold
Results 1 to 9 of 9
  1. #1 Downpipe bolts not sealing downpipe to manifold
    GT Level Member chicagochuck's Avatar
    Aug 2012
    Chicago
    I i had to disconnect my downpipe from the manifold but now I cannot get it to seal completely. I tightened the 13mm nuts as much as I think I can,(didn't want to break them), but its still leaking.
    Is it mandatory to change the whole bolt and nut to get it sealed properly? And the bolts are welded into the flange so would need to be drilled out from up top?
    Thinking to take to a shop tomm so wanted to know if this was feasible to do myself or not.
  2. #2 Re: Downpipe bolts not sealing downpipe to manifold
    Is the gasket still there?
  3. #3 Re: Downpipe bolts not sealing downpipe to manifold
    Aug 2012
    Chicago
    Its a zzp downpipe, if that matters. But Yes I changed it with a new walker gasket just to make sure it wasn't the old thin tin gasket.
  4. #4 Re: Downpipe bolts not sealing downpipe to manifold
    SWPA
    Did you put the gasket in right?
  5. #5 Re: Downpipe bolts not sealing downpipe to manifold
    Aug 2012
    Chicago
    I thought about that but Both sides look pretty much the exact same. and it did the same thing with the other flat thin gasket as well
    Maybe I can get a few more turns out of the nuts if they are heated...
  6. #6 Re: Downpipe bolts not sealing downpipe to manifold
    SWPA
    They shouldn't need to be heated. I had zero issues removing and reinstalling my ZZP dp several times over a few day period.
  7. #7 Re: Downpipe bolts not sealing downpipe to manifold
    Aug 2012
    Chicago
    hmmmm interesting
  8. #8 Re: Downpipe bolts not sealing downpipe to manifold
    Enfield, CT
    I bet the bolts need to be tightened more.
  9. #9 Re: Downpipe bolts not sealing downpipe to manifold
    Aug 2012
    Chicago
    I tightened up the bolts and that may have done the trick. its still loud as **** but it looks like it pretty much needs a weld after the cat. The flex pipe looks bad as well.
  1. Rusted downpipe bolts
    By Mirraco in forum General Grand Prix Discussion
    Last Post: 08-18-2015, 12:21 AM
  2. Downpipe bolts
    By jayroca in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-02-2014, 10:13 AM
  3. Downpipe bolts
    By Wakeboy1337 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-04-2011, 11:20 AM
  4. Downpipe bolts?
    By Bedwards in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-18-2009, 09:37 PM
  5. Downpipe bolts?
    By crywolf in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-05-2009, 09:35 PM
