Thread: Fuel gauge reading incorrectly
Results 1 to 2 of 2
  1. #1 Fuel gauge reading incorrectly
    Sep 2015
    IL
    Was working just fine, took off/disconnected throttle body as it needed cleaning and ever since the gauge has been going haywire. Sometimes reads empty, or full.. then graduates to correct reading after I've been driving a while. Doesn't stay that way though, it will move around as I drive occasionally. Anyone experience anything like this?
  2. #2 Re: Fuel gauge reading incorrectly
    Stranger things have happened before but it seems the level sensor gave up on life at the same time you did something else.
    Over time the fingers that run across the circut board on the level sensor break away and cause the issue you have. You can buy and replace just that part for fairly cheap. Under 20-30 bucks last time I did one, many threads regarding this issue.
  1. Fuel gauge reading wrong
    By Jason97GrandprixGT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-29-2015, 07:52 PM
  2. Temp gauge reading too low?
    By War97gtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-10-2014, 11:08 AM
  3. Problem with EGT gauge reading
    By camopaint0707 in forum General Tech Discussion
    Last Post: 07-31-2013, 04:23 PM
  4. Gas Gauge Not reading right-goes to empty
    By fixit10101 in forum General Tech Discussion
    Last Post: 08-07-2011, 12:33 AM
  5. Temp Gauge Not Reading RIght
    By 2000 Grand Prix GT Blue in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-28-2010, 12:08 PM
