Thread: airbox computer...
Results 1 to 8 of 8
  1. #1 airbox computer...
    Sep 2015
    ohio
    I got a spectre air filter to fit on the end of a tube starting from my throttle body just like a normal cold air intake and i went to go pull out the air box and realized that the computer is in the airbox... what did you guys do like where did you put it and how did you protect it from weather? I really don't want to get the K&N series 57 intake, because it is over $225 but, it is the only one i can find with a box to possibly put the computer in. Any suggestions on what i should do?
  2. #2 Re: airbox computer...
    Lay it on the frame lol.
    I left mine just sit there for years, even sold the car with it that way. The PCM is shock proof and weather proof. I mean it can get damaged but you'd have to throw it at the ground type of thing.
  3. #3 Re: airbox computer...
    GXP Level Member
    Mar 2015
    Tomball
    Put a piece of cardboard under it and wire tie it in place. You could also cut the bottom that holds the PCM out and place it back with the box all cut off. Or you could find a bracket in the JY that fits your PCM and use that or make your own bracket.
    Jeff
  4. #4 Re: airbox computer...
    GTX Level Member Travisgt2's Avatar
    Jan 2013
    leavenworth ks
    I cut the bottom off wasn't hard at all my first mod ever
    04 GT2: 180 t-stat, cold air intake, reptile tune, plog, hv3, gt1 cam, 90#springs, new push rods, new lifters, port polished heads, lim, uim and tb, 06 Impala brakes and steel brake lines. Cosmetic: black roof rails, under glow, Pontiac ground light, blue hud dic radio controls and cluster. To come custom hood.
  5. #5 Re: airbox computer...
    Mar 2014
    Tucson
    An S-10 PCM tray gives a little cleaner look, if that matters to you
  6. #6 Re: airbox computer...
    I think 90% of the guys on here just let her sit there.
  7. #7 Re: airbox computer...
    Sep 2015
    ohio
    I just tied it down where the airbox used to be and it is just fine.
  8. #8 Re: airbox computer...
    SWPA
    I cut out a piece of plastic and used heavy unused rivets to hold it in position where the airbox used to sit, then screwed the ecu to the plastic. Probably been that way 4+ yea4s now.
  1. GTX/SLP Airbox
    By Laid GP in forum Wanted To Buy - Parts
    Last Post: 10-26-2015, 09:33 PM
  2. ECU chip in airbox?
    By pontiac98 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-15-2013, 09:50 PM
  3. Does a 97-98 PCM fit in a 99+ airbox?
    By JBONE in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-14-2010, 11:49 PM
  4. What is in my airbox???
    By anicolay in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-08-2009, 12:49 AM
