Thread: Starts then dies
Results 1 to 16 of 16
  1. #1 Starts then dies
    Howell, NJ
    My car died on the way to work today. 97 GTP
    It will start up and idle fine for five seconds then just cut off, even if I rev it up. Never had this problem before.
    I tried running without the maf plugged in and it does the same thing.
    Any ideas guys?
  2. #2 Re: Starts then dies
    St. Louis
    Is the security light flashing? Tried another key in it? Other than that maybe try the fuel relay trick and put the pump into high-speed mode and see if it stays running then.
  3. #3 Re: Starts then dies
    Howell, NJ
    Quote Originally Posted by FordMan77 View Post
    Security light on the speedo or on the dash? The 97s dont have the key security thing
  4. #4 Re: Starts then dies
    Enfield, CT
    X2
    Sent from my LG G3
  5. #5 Re: Starts then dies
    GT Level Member JamesIvey24's Avatar
    May 2011
    Illinois
    My cps died today, after a 50 mile road trip. left it idling in a parking lot, came out..dead.
  6. #6 Re: Starts then dies
    im voting hi speed resistor.
  7. #7 Re: Starts then dies
    Howell, NJ
    That was it.
    Sent from my SM-N910V using Tapatalk
  8. #8 Re: Starts then dies
    winner winner chicken dinner!
  9. #9 Re: Starts then dies
    I wonder who told him that last night in the chat box..........
  10. #10 Re: Starts then dies
    with out the sarcasm font,,,,ill guess it was you lol
  11. #11 Re: Starts then dies
    Howell, NJ
    So what causes this to happen? v
  12. #12 Re: Starts then dies
    high speed resistor burned up. its in the fender by the battery if you care to change it.
  13. #13 Re: Starts then dies
    Howell, NJ
    Why does the resistor burn up? Will bypassing the resistor do any damage to the pump?
  14. #14 Re: Starts then dies
    its a resistor, they fail. most who bend the tab on the relay run it that way forever. or you can replace the resistor. your call.
  15. #15 Re: Starts then dies
    Antioch, IL
    twist wires together
    2009 Challenger SRT8
    Expert at being gay.
  16. #16 Re: Starts then dies
    Regal GS Level Member BoostedPontiac's Avatar
    Apr 2014
    South Haven, MI
    This is the reason i grab then at the junkyard. I keep 4 in my glove box.
    98' GP coupe NIC Pacesetters, E85, FSIC, 2.6, heads, blah
    11.82 @ 118.4 with a 1.8 60ft
    Retired: 99' Regal GS Turbo 11.428 @ 122.61 1.7 60ft.
    Retired: 99 GTP top swap nic setup. 13.37@106
  1. starts then dies
    By Zzp98gs in forum Engine
    Last Post: 09-10-2014, 06:56 AM
  2. 98 GTP starts and dies intermittently on cold starts
    By toadson in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-16-2013, 07:53 PM
  3. Car starts for a second then dies
    By Thedicktater in forum General Grand Prix Discussion
    Last Post: 07-20-2012, 04:36 PM
  4. Car starts then dies!
    By wa04compg in forum General Tech Discussion
    Last Post: 07-13-2012, 09:03 PM
  5. Starts then Dies!
    By 1999GTP1999 in forum General Tech Discussion
    Last Post: 01-29-2010, 08:42 AM
