Thread: Where is the EBCM on 1997 Grand Prix GT
Results 1 to 7 of 7
  1. #1 Where is the EBCM on 1997 Grand Prix GT
    GT Level Member mainecrab's Avatar
    Feb 2008
    Anyone know where this is? It doesn't appear to be under the hood attached to the brake booster like other models.
  2. #2 Re: Where is the EBCM on 1997 Grand Prix GT
    It should be right there on the strut tower, right next to the booster.
    It has like 4-6 lines from top comming out, and it's right next to the cruise control box.
  3. #3 Re: Where is the EBCM on 1997 Grand Prix GT
    Feb 2008
    I am not sure because I see no wires that could go it the sensors on the wheels.
    Here is the picture. It still looks like part of that brake system:
    http://s8.postimg.org/hetofamjp/20151120_200501.jpg
  4. #4 Re: Where is the EBCM on 1997 Grand Prix GT
    Feb 2008
    Or rather are only 6 wires not 8 going to it.
  5. #5 Re: Where is the EBCM on 1997 Grand Prix GT
    Feb 2008
    Nevermind I found it. It is a box under the dash on this model. Though still need to figure out how to get it out so I can get to the wires to test that none are broken before considering the part bad. Else I may have to find a shop that has a Tech 2 to test it and let me know if the module itself is bad. Though since seems all other years have them on the brake components under the hood. Seems would be protected inside the cabin. Looks like is held in place by plastic right next to the parking brake just hard to get in there easily.
  6. #6 Re: Where is the EBCM on 1997 Grand Prix GT
    your on the right track, i got the same crap abs pump. my abs lights, brake light and t/c light were all on, i got it scanned and its not a hub or the wires to one, but something else. the abs pump on the master has been changed, and the ebcm as well. careful the one you buy needs to be the same part # theres no interchanging them if you replace it. must be the same part #.
    you need to take the foot cover off under the dash and its up in the left side, mine had 3 plugs to it, the one in the back sucked to get off. you pretty much push it up and then to the side and it will un lock and you can move it around, i found if i unplugged the two plugs i could get to easy first, then pulled the unit out some then worked on the rear plug.
    your year has a relay in the dash too, that maybe bad. i changed mine, no help either tho. if you pull off the side cover of the dash or look up from under it, its just a relay clipped to the dash frame on the drivers side.
    i quit trying to fix mine. pulled the abs fuse, game over. ill live with the one yellow abs light on the dash.
    if you've not had it scanned for abs codes, do that first.
  7. #7 Re: Where is the EBCM on 1997 Grand Prix GT
    Feb 2008
    Luckily it ended up being a simple disconnected sensor harness. Next time though I'll be able to check and be in the know of what to do for testing.
  1. 1997 Grand Prix 3.8
    By nascarbumb in forum Introductions/Noob Questions
    Last Post: 04-26-2013, 11:23 AM
  2. 1997 Grand Prix SE
    By lurch2334 in forum Members Rides
    Last Post: 03-13-2012, 04:05 PM
  3. 1997 grand prix gtp's
    By zildjian102 in forum The Rant Forum
    Last Post: 02-26-2011, 12:09 PM
