Thread: 00 GT wont start...where to go from here?
Results 1 to 11 of 11
  1. #1 Re: 00 GT wont start...where to go from here?
    You should always have power aka positive voltage at the injectors. The pcm toggles the ground to operate them.
    Check your ICM connector and crank sensor connectors as well. Unplug your maf and map sensors. Then give it a try. I have seen a map/maf reading keep the pcm from giving the cylinders fuel.
  2. #2 Re: 00 GT wont start...where to go from here?
    GT Level Member glanzergtx's Avatar
    Dec 2008
    Sioux Falls,SD
    I got it to run. Since the MAP KPA was at 180 ish and i changed out the sensor and checked the wiring and didnt get it to go down, i wired it with the signal and power backwards to get me down to 41 KPA. after i did that the car started right up no problem. So clearly something in the computer disabled the injectors when the KPA is to high or out of table reach.
    Just your normal 730whp 4dr family car.
  1. 1993 grand prix 3.4 wont start have to pump gas to start
    By lookout in forum 3.4L V6 (LQ1) DOHC
    Last Post: 10-27-2015, 05:45 AM
  2. Topped swapped 06 GP now wont start and scan tool wont comm with ECM
    By jbrltoliver in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-31-2013, 08:36 AM
  3. car wont start
    By bmx6454 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-11-2012, 09:45 AM
  4. new used pcm car wont start
    By izup69 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-28-2011, 09:43 AM
  5. 1998 grand prix gt wont randomly wont start!!
    By franklin829 in forum General Tech Discussion
    Last Post: 01-18-2011, 01:26 PM
