Thread: Digital DIC NEED HELP ASAP
Results 1 to 5 of 5
  1. #1 Digital DIC NEED HELP ASAP
    Nov 2015
    lexington sc
    Hi im not new to this forum just forgot my log in but any who. I have a 2000 Grand Prix Gt Im currently trying to swap the old analog dic out with a digital one. All my wires match up except for. I have the green for the vss which I know where it goes. But out of my factory harness I have two grays and a gray with a black tracer. The connector for the digital dic has a brownish gray and 2 brownish grey with black tracer. the screen wont come on along with the lights when I turn on the lamps. the trac button works and the trac off and low trac light work. Anyone else run into this problem I could really use the help.
  2. #2 Re: Digital DIC NEED HELP ASAP
    Apr 2011
    Elk Rapids, Michigan
    2001 black GTP coupe, Gen V, ZZP S2IC & billet fuel rails, XP cam, LS7 lifters, 105# springs, ZZP MPS w/3.4 pulley, Northstar tb, LQ4 maf, ZZP headers, K & N CAI, Meziere electric wp, Caspers fp retire, F body front brakes, GMPP strut braces​, Don Rome strut brace mounts.
  3. #3 Re: Digital DIC NEED HELP ASAP
    Nov 2015
    lexington sc
    I read the forum and is what I used to get as far as I have but it hasn't helped with my problem
  4. #4 Re: Digital DIC NEED HELP ASAP
    Jul 2014
    New Jersey
    If its wired up correct the bulbs burn out sometimes
  5. #5 Re: Digital DIC NEED HELP ASAP
    GTP Level Member bonerjamz03's Avatar
    Apr 2009
    Upper Darby, PA
    The DIC went out on my 97 a few years back and I recently got around to pulling it apart, checking connections and replacing bulbs etc. Nothing worked. So I wound up buying a used DIC from a member on here and voila! it lit up right away and has worked ever since. I guess the board burned out over time. Not sure if that is what's happening in your case but it's something to think about.
  1. Digital Driver Information Center and Digital Climate Control
    By uNda6gT in forum Visual/Body Modifications
    Last Post: 03-28-2012, 10:47 PM
  2. Will a digital heater control work in a car without the digital?
    By Roanokegprix in forum General Tech Discussion
    Last Post: 11-05-2010, 08:04 AM
  3. Please Read ASAP, Need all ur input asap
    By SteelCityTA in forum Off Topic Discussion
    Last Post: 03-29-2009, 02:41 AM
  4. 97-03 Digital DIC & Digital HVAC Swap Question
    By StreetChariot in forum General Tech Discussion
    Last Post: 03-27-2008, 11:04 AM
