Thread: Low traction keeps coming on whenever I am turning
Results 1 to 6 of 6
  1. #1 Low traction keeps coming on whenever I am turning
    Feb 2013
    Saskatoon, SK Canada
    Hey guys. If I turn the wheel one full rotation to the left or right while braking (happens more), very rarely accelerating, it makes the low traction light come on and I get that weird sound the TCS makes. Not sure what any of the reasons could be besides wheel sensors
    Sent from my D6603 using Tapatalk
  2. #2 Re: Low traction keeps coming on whenever I am turning
    Jan 2014
    AR
    Dirty or wet connections or harness damage also cause that. On 97-03s the right front wheel harness is the first place I look.
  3. #3 Re: Low traction keeps coming on whenever I am turning
    Feb 2013
    Quote Originally Posted by idrivejunk View Post
    Thank you. Ill pull the wheel off and check.
  4. #4 Re: Low traction keeps coming on whenever I am turning
    ebcm does that too at slow speeds, turning into park spots is when it seems to act up for most.
  5. #5 Re: Low traction keeps coming on whenever I am turning
    Aug 2012
    Stonington, CT
    I second the right front wheel hub ABS/traction control speed sensor cable diagnosis. Either chafed or failing wiring or corrosion in the in-line wiring connector of the pigtail coming out of the hub. Caused repeatable trips of the ABS/Traction Control light on my 2001 GP SE on hard right rudder almost every time.
  6. #6 Re: Low traction keeps coming on whenever I am turning
    Apr 2014
    CT
    I also had to replace a good amount of the harness but on my left front. It seems.to brake right where it bends the most while steering. I had to keep cutting back because the wires were so corroded.
  1. Power Steering Stiff turning wheel Left Normal turning wheel right.
    By AdrianGTP in forum Brakes/Suspension/Chassis
    Last Post: 01-06-2017, 04:39 PM
  2. ABS and Traction Control not working but no ABS or Traction Control lights
    By jruether11 in forum Brakes/Suspension/Chassis
    Last Post: 02-22-2013, 04:40 AM
  3. Replies: 14
    Last Post: 02-20-2013, 10:47 PM
  4. Traction and ABS warning coming on
    By KenlochGT in forum General Tech Discussion
    Last Post: 01-02-2013, 02:30 PM
  5. Traction and ABS warning coming on
