Thread: Heat goes UP then down then up
Results 1 to 8 of 8
  1. #1 Heat goes UP then down then up
    GTP Level Member chevyy1212's Avatar
    Oct 2008
    IL
    Ok 07 GT it's my mommys... The heat takes forever to get up to temp then fluctuates from operating temp down to 140-150ish so the heat never stays at a good temp. I've changed the Tstat and the only thing I can think of is air left in the system? Any special way to bleed these I thought there was been years since I had my GS.
  2. #2 Re: Heat goes UP then down then up
    I'd backflush the heater core while your at it too.
    Then remove the thermostat, refill the LIM with coolant to get the level all the way up, re-install and top off the radiator. Run the car with the rad cap off and allow it to warm up, add coolant as needed. You shouldnt have to bleed through the T-stat housing doing it this way.
  3. #3 Re: Heat goes UP then down then up
    Oct 2008
    IL
    I like this plan. Is it just me but I remember these cars being a pain to get the air out of the system?
    1998 GS with Open cone, PLOG, ZZP Catless DP, tune & Intense MPS 3.6. Pulls good enough to make the woman smack me and call me a D!*k.
  4. #4 Re: Heat goes UP then down then up
    I just think some people have bad luck???
    I've never ran into a issue with one yet, worked on dozens of 3800's and never had a issue yet. Sure some take longer but knowing a few tricks of the trade help. Squeezing hoses, revving the motor, quick shuts offs to burp it and so on.
  5. #5 Re: Heat goes UP then down then up
    ive yet to have air bound core but it sure does seem to happen to a lot of cars here.
  6. #6 Re: Heat goes UP then down then up
    Oct 2008
    IL
    Quote Originally Posted by ScottyDoggs View Post
    Yea she got screwed out of 3 flushes at a shop a few years back after I took it flushed the heater core and bleed it off a few times been good for years now it's doing it again after the resivour hose got ate up buy the belt. Very few things can cause this tho. I jacked up the front end for kicks while bleeding too.
  7. #7 Re: Heat goes UP then down then up
    bleeding the t stat wont fix air in the heater core. the core needs to be filled up. take both hoses off the alt bracket, and flush one with a garden hose, then flush the other one, then put the hoses back on with them as full of water as possible.
  8. #8 Re: Heat goes UP then down then up
    Oct 2008
    IL
  1. Heat ...Well, Sometimes Anyways...
    By eastcoastcam in forum General Grand Prix Discussion
    Last Post: 03-03-2014, 11:54 PM
  2. No heat on drivers side, but heat on passenger side.
    By maceman in forum General Tech Discussion
    Last Post: 04-05-2013, 06:57 PM
  3. no heat
    By Couch in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-28-2012, 09:03 AM
  4. No Heat, Need Help.
    By speed24 in forum General Tech Discussion
    Last Post: 12-17-2009, 03:50 PM
  5. How much does heat......
    By GTP4 in forum PCM Tuning
    Last Post: 05-08-2009, 11:54 AM
