Thread: solved
Results 1 to 12 of 12
  1. #1 solved
    Mar 2015
    USA
    solved
  2. #2 Re: Mysterious repetitive clunk/pops on accelerating and braking transmission going b
    My 01 GTP did this too, I have no idea what caused it, but always when stopping and taking off. I sold the car and it still did this. And 105k miles on a 3800 powered car is not high miles, that things just barely broke in.
  3. #3 Re: Mysterious repetitive clunk/pops on accelerating and braking transmission going b
    SE Level Member onenayr92's Avatar
    May 2014
    Choctaw, OK
    this was happening to my 2000 grand prix GTP. I replaced just about everything you listed above suspension-wise. And that eliminated about 90% the popping noise for me. Did the control arm come with the ball joints? THose being bad are known to cause that noise. Try replacing the transmission mount too. I replaced my transmission mount with a polyurethane bar that i cut to fit and drilled holes in and that completely eliminated the popping.
  4. #4 Re: Mysterious repetitive clunk/pops on accelerating and braking transmission going b
    Transmissions tend to be driver specific. If you are an abusive driver, the trans will usually not last.
  5. #5 Re: Video Included: Mysterious repetitive clunk/pops on accelerating and braking.
    Just for the hell of it, loosen all the front brace bar bolts that run from the rad support to the strut tower, then tighten them again.
    I've seen it a few times where they were loose and made a clunk noise.
  6. #6 Re: Video Included: Mysterious repetitive clunk/pops on accelerating and braking.
    GT Level Member mguzzo's Avatar
    Buffalo NY
    sounds like a dry bushing. Like it gets unloaded when you accelerate and then it groans as it loads up and settles.
    I'd check the LCA bushings, and also check the exhaust hangars and make sure the downpipe isn't rubbing anywhere.
    "Silver Bullet" 98 GTP Coupe: Stock, rust free, and broadsided.
    Old '98 GTP Coupe: VS Cam, 3.0, S2IC, 42.5#, TOGs, N*/LQ4, Corsa. it once ran a 13 flat
    Older '98 GTP Sedan: Pullied, rockered, SSIC, etc. Stock 14.33 @ 96.5 / PB: 13.89 @ 101
  7. #7 Re: Video Included: Mysterious repetitive clunk/pops on accelerating and braking.
    SE Level Member Drive XR7's Avatar
    Cleveland, OH
    My 01 GTP does this too. No idea what's causing it. Sounds very similar.
    Jason
    2001 Bronzemist Pontiac Grand Prix GTP - SOLD!
    2003 Sonic Blue SVT Mustang Cobra Convertible #2421 (1 of 340)
    2013 Ruby Red Ford Edge Limited EcoBoost
  8. #8 Re: Video Included: Mysterious repetitive clunk/pops on accelerating and braking.
    Buffalo
    How you tried this while the car is parked?
    Open the hood , and rock the car back and forth (push on the rad support)
    You can inspect the upper motors on the radiator support and on the dog bones.
    You could also hear:see the lower mounts.
  9. #9 Re: Video Included: Mysterious repetitive clunk/pops on accelerating and braking.
    Donating Users isukathalo93's Avatar
    Sep 2012
    Waterford MI
    I know no one has responded to this in a couple of weeks, But did anyone mention the rear 2 subframe bushings? I know its rare for them to go bad but they did on my car and i would get a loud couple of clunks every time i would accelerate or come to a quick stop. Also it would explain why the OP says it sounds like its coming from the passenger floor that's around the area where one of the bushings sits.
  10. #10 Re: Video Included: Mysterious repetitive clunk/pops on accelerating and braking.
    Buffalo
    Who knows. OP never responded
  11. #11 Re: Video Included: Mysterious repetitive clunk/pops on accelerating and braking.
    I can't car too good. SaukRapids's Avatar
    May 2016
    MN
    Upper strut mount? I gotta be honest and say that I can only hear interior noises in the video.
  12. #12 Re: Video Included: Mysterious repetitive clunk/pops on accelerating and braking.
    GTP Level Member
    Jun 2016
    Cleveland ohio
    The video has too much interference noise. Make sure the LCA bolts are very tight. Along with the balljoint nut. Basically go over and tighten everything; subframe, rack bolts,etc.... Do you have stock cv axles?
  1. Get a Clunk sound when accelerating
    By IronShot in forum Brakes/Suspension/Chassis
    Last Post: 04-23-2015, 05:09 AM
  2. transmission clunk
    By Grimsin in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-01-2014, 06:22 PM
  3. Mysterious grind only while braking
    By techweenie in forum Brakes/Suspension/Chassis
    Last Post: 06-20-2011, 07:06 PM
  4. Clunk when coming to stop and/or accelerating
    By trailshredder in forum Brakes/Suspension/Chassis
    Last Post: 04-01-2010, 05:43 PM
  5. repetitive posts
    By gtpinsc in forum Forum Bugs/Suggestions
    Last Post: 12-05-2009, 09:52 PM
