Thread: CV Boot replacement
Results 1 to 12 of 12
  1. #1 CV Boot replacement
    Donating Users
    Aug 2011
    Covington GA
    Does anyone have pictures or a video on how to replace a CV outer boot passenger side 1998 Grand Prix SE? Used a quick boot but that did not last. Do I have to pull the axle out or can it be replaced without pulling the axle?
  2. #2 Re: CV Boot replacement
    http://www.grandprixforums.net/threa...ight=easy+bill
    He did a lot of How to's just search easy bill in the search box
  3. #3 Re: CV Boot replacement
    Just replace the axle itself, you are just making more work for yourself trying to reboot it.
    Axles are like 70 bucks now with warranty and boot kits are almost half that and you already have to remove it from the car to do it correctly.
  4. #4 Re: CV Boot replacement
    Donating Users
    Aug 2011
    Covington GA
    I thought about that as well, went in to look at reviews on the axle you get from Autozone, Advance Auto and the rest of them, most received no more the 2.5 stars. Stating within a year they had to replace again so I rather keep the original and get a OEM quality boot. Thanks
  5. #5 Re: CV Boot replacement
    GTP Level Member LeadfootCJ7's Avatar
    Oct 2012
    Houston, TX
    I found someone local who serviced CV's. He put a OE quality boot on my 94 CS and it was perfect and has held up often. I think it was $25 - $30 for the parts and all. I took the CV shaft to him.
    2007 Grand Prix GXP;2002 Camaro Z28 - tune, CAI, and exhaust
    2006 GMC 2500HD - ATS high flow manifolds and uppipes, turbo back exhaust, blocked EGR, Denali headlights, Reflexxion Cown Hood
    1994 Olds Cutlass Supreme 2 door
  6. #6 Re: CV Boot replacement
    Get some Napa remanuf
    04 Comp G.
  7. #7 Re: CV Boot replacement
    Donating Users
    Aug 2011
    Covington GA
    Okay guy's bought a remanuf axle from NAPA, having trouble getting the old axle off the trans. Any suggestions? tried turning it to remove it from different angles, bought pry bars but do not want to smash the seal.....HELP!!!!
  8. #8 Re: CV Boot replacement
    Stick a pry bar in from the bottom and get between the axle and diff housing and one swift move and it should pop it out of the trans.
  9. #9 Re: CV Boot replacement
    Enfield, CT
    NAPA's reman and new are Cardone. From all the stuff I've seen personally, Cardone remans for the w-bodies are no longer good quality. The new ones are balanced true and very solid these days. Gonna get a new one for the gf. Let you know how it is in a few months lol.
    Sent from my LG G3
  10. #10 Re: CV Boot replacement
    Oct 2012
    Houston, TX
    Yep, The Cardone I got for my 94 CS was too long. After some research I found that is typical because they assume your mounts and such are worn changing the angle which makes you need a longer shaft. The quality of it was def below par. That when I took my 200K+ CV shaft to have a new boot put on. The guy who did it told me the OEM are the best as long as they have not been contaminated or damaged.
  11. #11 Re: CV Boot replacement
    Enfield, CT
    Yea well OEM ones cost a fortune these days.
    Sent from my LG G3
  12. #12 Re: CV Boot replacement
    Oct 2012
    Houston, TX
    Quote Originally Posted by HighOctaneRacing View Post
    Sent from my LG G3
    Agreed, but I had my OEM and the only thing wrong was a torn boot. He inspected it and said it was in great shape. When I told him it had 200K+ miles on it he chuckled and said that's why he recommends keeping the OEM if you can.
  1. Help with inner tie rod boot
    By nukkinfuttz in forum Brakes/Suspension/Chassis
    Last Post: 05-27-2014, 01:53 PM
  2. Pcv cap and Vacuum boot
    By holorinhal in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-10-2013, 06:53 AM
  3. Inner tie rod boot
    By bonerjamz03 in forum Brakes/Suspension/Chassis
    Last Post: 10-16-2010, 08:40 PM
  4. Boot this nikencshoes guy!!
    By Nickell in forum Forum Bugs/Suggestions
    Last Post: 12-02-2009, 05:07 PM
  5. Did my CV boot blowup?
    By GeddyLee in forum Brakes/Suspension/Chassis
    Last Post: 05-02-2008, 11:12 AM
