Thread: Knock, knock, knock (Who's there?)
Results 1 to 11 of 11
  1. #1 Knock, knock, knock (Who's there?)
    Mar 2015
    Connecticut
    A few minutes after I start driving (when the engine is cold,) I hear a faint "knock, knock, knock" sound. Always three, same even spacing. Can't tell where it's coming from. I assume since it's consistent that it's something normal, but I'm curious what it is.
    '01 GTP
  2. #2 Re: Knock, knock, knock (Who's there?)
    if it goes away its kinda normal, its a lifter is loosing pressure when it sits over night. oil change used to stop it on my car. if it started to tap, i knew i was over due for sure lol
  3. #3 Re: Knock, knock, knock (Who's there?)
    Sometimes running some seafoam in the oil for like 50-100 miles before an oil change will help.
  4. #4 Re: Knock, knock, knock (Who's there?)
    Mar 2015
    Connecticut
    Quote Originally Posted by ScottyDoggs View Post
    It doesn't sound like that. It sounds like a solenoid or something it being triggered. There are always exactly three knocks, and they are always spaced exactly apart by the same amount of time regardless of engine RPM.
    It's quiet enough that if you had the radio on, and/or were already driving fast enough for engine/road noise, you probably wouldn't hear it.
    And I just had an oil change within the past month.
  5. #5 Re: Knock, knock, knock (Who's there?)
    Wes...you know my feeling, the radio can always go louder.
  6. #6 Re: Knock, knock, knock (Who's there?)
    Mar 2015
    Connecticut
    I tried recording it this morning, with my phone on the dashboard. I heard it "live," but can't hear it in the recording. Tonight I'll edit the audio file and press the "enhance" button several times.
    Again, I don't think it's a problem, I'm just curious what it is. Wondering if it's related to some emissions equipment that doesn't "kick in" until the engine has warmed up a little bit.
  7. #7 Re: Knock, knock, knock (Who's there?)
    Oct 2011
    Toledo, OH
    Don't worry, my 05 does it too, so did my 01 Firebird. Pretty sure it's something to do with the evap canister solenoid or something.
    7"
  8. #8 Re: Knock, knock, knock (Who's there?)
    GT Level Member mkyota1's Avatar
    Daytona, florida
    My 04 deville does it too. Weird. Normally 3 or 4 mins after cold start.
    R.I.P.-----99 black GTX 12.9@107
    97 gp gt turbo--- Hx35, xp cam, 130#, double roller, hv3, l67 block, 42.5#, crap tune by me+ Dhp, devils own injection
    300m, 7/8" 2.93 11.78@118
  9. #9 Re: Knock, knock, knock (Who's there?)
    I'd say it's the EVAP solenoid.
    My silverado did it too but I could only hear it when it used the remote start and I was standing beside it.
  10. #10 Re: Knock, knock, knock (Who's there?)
    Jul 2012
    Chicago
    My Bonne does this occasionally as well, sounds like it's coming from the back.
    -Carl
  11. #11 Re: Knock, knock, knock (Who's there?)
    May 2015
    FORT WAYNE, INDIANA
    I used to have a 98 Grand AM that did 3 quick little knocks that sounded like it was coming from the back. Did not have to be certain temp it would do it at a light after driving awhile or sometimes soon after startup.
  1. Rod Knock?
    By 87IROCZOWNER69 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-03-2013, 10:29 PM
  2. Is it knock?
    By radiocrash in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-03-2012, 12:30 PM
  3. Listen to the knock knock knock....
    By Lsick7 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-23-2011, 05:40 PM
  4. Knock Knock - What is it?
    By Blown97 in forum Brakes/Suspension/Chassis
    Last Post: 11-11-2009, 12:28 AM
  5. How much knock is ok
    By jacobmh27 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-10-2009, 05:35 AM
