Ah, that's why I couldn't find one, thanks!
It's not very useful information if you don't explain why you don't think he's right. Just emailed cardone and asked, they suggested the same part.
Probably because it's supercharged, my gt is as well
Hmm, so the 661256 is still usable, correct?
Hmm...
The passenger side(right side) is the axle that is different. Idk wtf Kyle is talking about. If he was referring to the axle itself I only posted it as a reference.
"How to Determine Vehicle Side
So, how do drivers determine which side of the vehicle is which? It’s as easy as sitting inside the vehicle. While sitting in the driver’s seat, the right side of the vehicle is to the driver’s right, effectively the passenger’s side. The side a driver is sitting in is the left side of the vehicle. Simple and easy. So, the next time shoppers are looking online for car parts, they can just envision themselves sitting behind the wheel."
Ok... So any regular one will work on the left or do I need a hd?
It's supercharged, seems to be a misunderstanding due to previous gts not being supercharged prior to 05. After 05 they dropped the gtp and supercharged the gt instead. So, yes.... It's most definitely supercharged....
Gp is grand prix, I'm just shortening it.
04-05 the gt was na and the GTP was supercharged. In 06 they dropped the GTP model and made a base, a gt and a GXP.
I'm trying to make sure that's the case, I want to make sure I'm getting the correct parts so I don't shred a cv.
from rockauto. see right side, left side. pretty simple aint it?
APWI GM8222
Front Left![]()
$33.89 $0.00 $33.89
SURTRACK GM8045 Does Not Include ABS Ring
Front Left![]()
$34.99 $0.00 $34.99
APWI GM8223
Front Right![]()
$36.79 $0.00 $36.79
SURTRACK GM8097 Does Not Include ABS Ring
Front Right![]()
$43.79 $0.00 $43.79
CARDONE SELECT 661255 {#20859642} CV Drive Axle; Does Not Include Retaining Clip
Front Left; Supplied w/Standard Neoprene Outboard Boot$49.79 $0.00 $49.79
EMPIRE 801818 Empire New
Front Left![]()
$49.99 $0.00 $49.99
CARDONE SELECT 661256 CV Drive Axle; Includes Retaining Clip
Front Right$50.79 $0.00 $50.79
EMPIRE 801820 Empire New
Front Right![]()
$57.79 $0.00 $57.79
CARDONE SELECT 661255HD
Front Left; Supplied w/Optional Heavy Duty Thermoplastic Outboard Boot$65.79 $0.00 $65.79
A-1 CARDONE 601255HD Reman.
Front Left; Supplied w/Optional Heavy Duty Thermoplastic Outboard Boot$54.79 $13.50 $68.29
ACDELCO 20859642 GM Original Equipment
Front Left; Trans. code 4T65-E-HD/MN7![]()
$197.99 $0.00 $197.99
ACDELCO 19256583 GM Original Equipment
Front Right; Trans. code 4T65-E-HD/MN7![]()
$465.79 $0.00
Rockauto will only list the ones for the supercharged car as long as you select the supercharged car. So if you need the passenger side you order the right side, if you need the drivers you order the left.
