Agreed. Out of town at a conference but sweetie agreed to take it in to the local tire place for an alignment and re-balance. Will see if it did the trick. Bear in mind these are brand new Goodyear tires.
Funny thing about the noise...once you got to 35 or so, you could hear this scraping crunching grinding noise, and it was loudest with the passenger window down. Didn't get louder if you went faster, didn't go away until you got down below 20 or so. Th bearing had so much play I figured it was the problem, but it wasn't making the noise, it was the axle.
I only had a verrrry slight vibration before I did anything....the vibration didn't get bad until I changed the hub, axle and brakes. If the tire balance and alignment doesn't fix it, next will be hub and axle on the drivers side. Stay tuned.
