The last two codes are transmission related code, both are likely causing the jerking and stuttering feeeling you are getting.
P0742 is a TCC stuck on code I believe and the P1811 is a max adapt shift/long shift code. I'd either recommend a rebuild at this point or open the transmission up and repair what is needed but if you went that far, just rebuild it.
