Thread: Is there a thread on how to remove your rear exhaust manifold?
Results 1 to 11 of 11
  1. #1 Is there a thread on how to remove your rear exhaust manifold?
    Slower, Lower Delaware
    Can it be removed from the bottom?
  2. #2 Re: Is there a thread on how to remove your rear exhaust manifold?
    what part are you hung up on?
    if you drop the read of the sub frame you can slide it out the bottom, seen vids of them coming up the top as well tho.
  3. #3 Re: Is there a thread on how to remove your rear exhaust manifold?
    Haven't started it yet. It looks like to me you have to remove a lot of stuff to fit it through the top. I'm just looking for the fastest way before I start.
  4. #4 Re: Is there a thread on how to remove your rear exhaust manifold?
    GTP Level Member
    Jan 2015
    Lincoln, NE
    Personally I would go out the top to avoid messing with the downpipe. Just take the dog bones loose and prop the motor forward. Hardest part will probably be separating the egg I would think
    - 2001 Grand Prix XGT -- 11.21@124MPH
    - 2010 Chevy 2500HD LTZ -- Car hauler
    - 2011 BMW 328i Xdrive -- Wife's Daily
    - 2014 Ford F250 crew cab -- 6.2 liters of ford fail
  5. #5 Re: Is there a thread on how to remove your rear exhaust manifold?
    start with the cross over pipe. easier if the front manny comes off first, take the dp off lower the frame a few inches and its out.
    new rear header slides right back up the way the stock one came out.
    13 mm ratcheting box wrench makes the bolts to the heads a bit easier.
    bills got the header how to covers removal of the stock crap. http://www.grandprixforums.net/threa...he-easy-method
  6. #6 Re: Is there a thread on how to remove your rear exhaust manifold?
    Quote Originally Posted by NebTurboST5 View Post
    now way its coming up the top with the dp on it still, it wont hardly come out the bottom with it on still. it needs to come off really.
    whats the plan here? header install? or just replacing the rear manny due to a crack or something?
  7. #7 Re: Is there a thread on how to remove your rear exhaust manifold?
    I'm putting ZZP's new rear plog on. The DP has to come out to have a bung put in it for wideband anyway.
  8. #8 Re: Is there a thread on how to remove your rear exhaust manifold?
    first 1/2 of bills header install will clear it up. the cross over can stay put i bet.
  9. #9 Re: Is there a thread on how to remove your rear exhaust manifold?
    Enfield, CT
    This. Works all the time as long as you disconnect the DP.
    Sent from my LG G3
  10. #10 Re: Is there a thread on how to remove your rear exhaust manifold?
    mine had no chance of coming out that way and i tried cause my dp bolts stripped.
  11. #11 Re: Is there a thread on how to remove your rear exhaust manifold?
    Write up looks great, thank you Bill. It will save me a lot of time. Thanks to all of you and especially ScottyDoggs. I always like to have a change made to my car before street racing each year at the OC Endless Summer Cruisin'. Oops, I mean cruising at OC.
  1. Rear exhaust manifold
    By xxburkettxx07 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-17-2014, 10:03 AM
  2. WTB Ported Rear Exhaust Manifold
    By K Kraziee in forum Wanted To Buy - Parts
    Last Post: 06-07-2014, 04:40 PM
  3. Looking for pictures of stock rear exhaust manifold runners!
    By 97AutoXVette in forum General Tech Discussion
    Last Post: 03-27-2014, 01:03 PM
  4. Header and manifold Thread
    By TheOtherNick in forum General Tech Discussion
    Last Post: 08-27-2012, 10:31 AM
  5. 3.1 water coming from exhaust leak on exhaust manifold
    By ibhuff in forum 3.1L V6 (LHO/LG8)
    Last Post: 10-21-2011, 01:54 PM
