Thread: 3.5 pulley chirping
Results 1 to 15 of 15
  1. #1 3.5 pulley chirping
    Feb 2015
    california
    Recently went to a 3.5 zzp module system pulley and new gatorback 660 belt. Started getting a chirping sound from the pulley belt area.. Belt looked pretty worn after only a couple of days. Is the belt too tight? too loose? or do i have a bad tensioner? Pulley installed wrong?
  2. #2 Re: 3.5 pulley chirping
    Feb 2015
    california
    I came across this on the web how do I know which category id fit into? I have a 2002 gtp
    667 - Gen 5 blower stock belt GTP/GS/SS supercharged with stock 3.8" pulley (67 1/4" -1708mm)
    663 - Gen 3 blower stock belt GTP/GS/SS supercharged with stock 3.8" pulley (66 7/8")
    660 - GTP/GS/SS supercharged with 3.3 - 3.7" pulley (66 3/4")
    658 - GTP/GS/SS supercharged with 3.2 - 3.6" pulley (66 3/8" - 1687mm)
    653 - GTP/GS/SS supercharged with 3.1 - 3.5" pulley (65 7/8")
    650 - GTP/GS/SS supercharged with 2.8 - 3.1" pulley (65 1/2")
    645 - GTP/GS/SS supercharged with 2.6 - 2.8" pulley
  3. #3 Re: 3.5 pulley chirping
    Apr 2015
    Lincoln NE
    You have the right belt for it. you want 660-653. Im not sure about the noise though
  4. #4 Re: 3.5 pulley chirping
    Feb 2013
    Missouri
    Where do you have the belt riding on the pulley? Mine chirped whenever it wasn't centered on the pulley (one rib extra on each side).
  5. #5 Re: 3.5 pulley chirping
    Feb 2015
    california
    oh mine is at far left
  6. #6 Re: 3.5 pulley chirping
    Feb 2013
    Missouri
    Try putting it in the middle. I literally went through the exact same thing, lol.
  7. #7 Re: 3.5 pulley chirping
    Oct 2013
    michigan
    Quote Originally Posted by Booba5185 View Post
    for whatever reason mine started when I put a new belt on and removed the a/c compressor. now that I have since replaced the compressor it has since stopped.
    01 gtp SD headers. gen V swap. hai. zzp 1.0 pcm. 06 Impala brakes. GMPP sway bar.
    01 ram 2500 870hp/1796lbft fmw s467.7 w/n20 old. new 66/86 compounds ????hp/????lbft.
  8. #8 Re: 3.5 pulley chirping
    Feb 2013
    Missouri
    Your clutch on the compressor was dragging a bit.
  9. #9 Re: 3.5 pulley chirping
    Oct 2011
    Toledo, OH
    Same here
    7"
  10. #10 Re: 3.5 pulley chirping
    GXP Level Member
    Mar 2015
    Tomball
    I went up a pulley size from a 3.4 to a 3.6 with a 660 and started getting a chirp, then a squeal several days later. It was the tensioner pulley.
  11. #11 Re: 3.5 pulley chirping
    Feb 2015
    california
    seemed to fix the problem thanks!
  12. #12 Re: 3.5 pulley chirping
    Oct 2013
    michigan
    still on a completely separate belt. should have no effect on the blower belt walking/not walking.
  13. #13 Re: 3.5 pulley chirping
    Feb 2013
    Missouri
    SO your supercharger belt moved?
  14. #14 Re: 3.5 pulley chirping
    Feb 2015
    california
    Belt wasnt on middle of pulley it. That was the problem.
  15. #15 Re: 3.5 pulley chirping
    Oct 2013
    michigan
    correct. it was just odd I changed nothing other than reinstalling an a/c compressor in place of the delete pulley.
  1. Pulley or belt chirping noise on start up or cold
    By Jonarin in forum General Grand Prix Discussion
    Last Post: 10-14-2014, 08:48 AM
  2. chirping sound?
    By TEK310 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-03-2012, 08:15 PM
  3. chirping noise
    By gpgt98 in forum General Tech Discussion
    Last Post: 07-07-2011, 07:13 AM
  4. chirping
    By Ricky21 in forum General Tech Discussion
    Last Post: 05-24-2010, 07:07 PM
  5. Chirping Noise
    By TeeWX in forum General Tech Discussion
    Last Post: 09-02-2009, 07:29 PM
